Bad Noise - Upper Engine
Old Sep 3, 2008 | 04:44 PM
100percentcotton's Avatar
100percentcotton
Its kind of hard to describe, but I'm getting kind of a rotational grinding noise at idle. It sounds like its coming from the passenger side top of the engine. Which leads me to believe that it would be the supercharger. My 02 S only has 30K miles and I'm really wondering what is going on? Anyone have a similar problem? Any advice would be greatly appreciated.
Old Sep 3, 2008 | 05:39 PM
JAB 67's Avatar
JAB 67
Thats what my '04 MCS sounded like before my s/c failed at 16K.
Old Sep 3, 2008 | 06:04 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
before you start to tear apart your engine check to see if the tensioner pulley for your serpentine belt is functioning properly. This sounds like the grindy rattely noise of one of these going haywire
Old Sep 4, 2008 | 07:56 AM
thatatvguy's Avatar
thatatvguy
Sounds can "sound" like they are coming from all kinds of areas.
Prob the s/c and or the water pump. That's the most common. Unfortunately.
Take a "stethoscope" type listening device and "pin-point" the noise.
That's not to say that it "could" be the belt tensioner.
Might be the timing chain tensioner, but unlikely.
Old Sep 6, 2008 | 04:47 PM
100percentcotton
Thanks for all the help. It turns out that the oil in the supercharger was way down. I refilled it with gear oil and for the time being all is well, but I'm definitely going to keep an eye on it.
Old Sep 7, 2008 | 04:58 AM
chadtoolio's Avatar
chadtoolio
Did you check both sides? It requires removal of the SC.
Old Sep 7, 2008 | 02:47 PM
k_h_d's Avatar
k_h_d
How did you check the gear oil? I assume you had to tear apart alot of the front end to get to it?
Old Sep 8, 2008 | 12:46 PM
100percentcotton
no I only checked the passenger side because that was definitely the source of the noise. There is an easily accessable drain plug on the s/c that allows for the level to be checked and added to if necessary. No disassembly required
Old Sep 8, 2008 | 06:17 PM
chadtoolio's Avatar
chadtoolio
Be aware that there are a set of gears that will fail if run low on oil on the other side...
Old Sep 9, 2008 | 08:14 AM
junglemini17's Avatar
junglemini17
I would be interested in knowing how to check the gear oil. Could you maybe explain how you whent about doing that.
Thanks!
Old Oct 6, 2008 | 01:39 PM
100percentcotton
Thanks!
Sorry I'm a little late on my response. If you follow your engine oil dipstick tube down, you will see a torx key drain plug on the side of the s/c. The gear oil should start to come out a little upon taking the plug out.
maestro39
Oct 27, 2015 02:38 PM
David.R53
Sep 1, 2015 06:49 PM
damncajun
Aug 17, 2015 08:25 PM
Fizzyx
Aug 14, 2015 08:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
