I just bought some NGK Iriduim plugs and I forgot to ask about plug gap. The box doesn't say if they're pre-gapped or not. Does anyone know if they're pre-gapped and if not what I should gap them to....
no, no they are not. Iridium models are not OEM MINI which means they are not gapped properly. Only models ending in 'IX' are pregapped and then, not necessarily for the MINI. Be sure to check the service manual and gap properly.
never assume ANY plug is pre-gapped always check them.
We tried BKR7EIX in my car and gapped at .32 and at .28...pinging still. We swapped for some Brisk Silvers and made 10 lb/ft of tq on the same map.
With my mods a NGK ZFR6FIX-11 gapped at .46 tried .50 but it started to miss at 5k rpm so I went back to .46
Now I run AC Rapid Fires at the same gap with no pining no problems.
Plug pictures is with 3k miles mountain twisties.
The point is every Mini is different, consider to stay with the oem recommendation unless you are willing to experiment and learn how to plug read correctly.
What gapping is better for performance?
What spark plugs do you suggest for a 1 step colder than stock MCS application?
I am kinda new to the world of minis but when you increase boost beyond a certain point you use a 1 step colder plug to lower the chance of detination. I am not sure waht a 17% pully does to boost levels but 1 step cloder is not for hp gains as much as it is to save your engine.
Or you could just run meth. injection.
As for HP gains try using copper plugs, They provide more power. The only reason peopl use platinum and iridium is because the last longer. Some say If you use copper plugs that you have to change them every 10k miles or so but the perfomance is worth it.
I myself have never used copper plugs, I just like to research.
we have the single electrode and the factory like 4 prong that work well with the pullied cars. The single are better for cars with a head and bigger boost
