Madness rear trailing arm bushings
Old Jul 18, 2008 | 02:02 PM
MINI-Madness's Avatar
MINI-Madness
Madness Rear Trailing Arm Bushings
Madness BMW Mini Cooper S polyurethane rear Rear Trailing Arm Bushing inserts. These Polyurethane Rear trailing arm Bushings help keep your Mini Cooper S on track by striking a balance between comfort and performance. The high performance polyurethane used to make these Mini Cooper S bushings arrest suspension play. This reduces that loose feel that can diminish the other improvements you have made to your suspension. Easy installation requiring no removal of the existing bushings. These bushings are inserts that fill the negative voids of the factory rubber bushings.
By replacing these bushings you tighten the rear suspension and limit the movement caused by hard cornering with soft factory bushings. More control as well as better feel is transmitted to the driver by limiting the lateral strut movement.
If you've already upgraded the rest of your suspension then your missing a big part of the equation by not having these polyurethane rear control arm bushings. Precision machined to exacting tolerances, these rear suspension bushing eliminate 99% of rear trailing arm play!
Kit includes: 4 bushing inserts and Installation instructions
Fits all models 5/2003 and above, will not fit 2002 models
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
