R56 Optimal Cruising Speed for best MPG
Old Jul 18, 2008 | 07:00 AM
Duffer's Avatar
Duffer
What's the optimal interstate cruising speed to achieve the best MPG?
Old Jul 18, 2008 | 07:09 AM
jw34's Avatar
jw34
From what I've gathered 65 or under (which is hard in this car).
Your mileage may vary
Old Jul 18, 2008 | 07:14 AM
JCR1960's Avatar
JCR1960
Technically driving 55 mph will offer the better MPG but I doubt most drive that speed.
There are a lot of variables to consider but the way I achieved my best MPG of 38.4 MPG on the highway was by periodically watching the average MPG on the OBC once I saw that figure and it wouldn't go any higher I maintained that speed approx. 70 mph by setting the cruise control.Keep in mind that was in an automatic with luggage while I was traveling from South Florida to Minnesota and back.
Old Jul 18, 2008 | 09:32 AM
DanQ's Avatar
DanQ
Someone with a scangaugeII could chime in, but I'd guess the best MPG for a MC is probably around 45-50 mph. Probably 45 actually. That seems to be the best speed for most cars I've seen in hypermiler forums. I can confirm after our car is delivered.
Old Jul 18, 2008 | 09:36 AM
BobsElise's Avatar
BobsElise
I recently drove my car to Maine and back. On my first tank of gas which took me 576 miles from NC to NJ, I cruised at a maximum of 73 indicated (70 by GPS). There were also stretches where I cruised slower when the speed limits were lower. I averaged a hand calculated 40.1 MPG (41.6 on the trip).
Old Jul 18, 2008 | 10:43 AM
glangford's Avatar
glangford
I did a 200 mile interstate run and had my OBC say 49.7 mpg. (My OBC is 2-3 mpg optimistic) I cruised at 65 (w/cruise on), no ac, and window about half way down, tires +1 psi over recommended.
Air resistance goes up by the square of the speed, and as such speed increases will have a more pronounced effect as the speed goes up.
Old Jul 18, 2008 | 10:47 AM
Gil-galad's Avatar
Gil-galad
+1. I believe the "knee in the curve" of aerodynamic drag versus fuel efficiency is in the mid-40s mph. Of course, this assumes a certain engine /transmission efficiency and road friction, level ground, no acceleration, etc. If you're climbing steep hills in high gear into a stiff wind with under-inflated tires at 45 mph you're obviously not going to win any mpg contests...
Old Jul 18, 2008 | 10:58 AM
Robin Casady's Avatar
Robin Casady
My impression is that 45 is about optimum, but I haven't analyzed it carefully. Turning the AC off is important for mpg.
I have a ScanGaugeII, but you can see instant mpg figures on any MINI by setting it on your tach readout. See your manual for changing the readout.
Old Jul 18, 2008 | 11:07 AM
DanQ's Avatar
DanQ
right, but the scangauge does a better job of keeping trip mpg ave, day mpg ave, yesterday mpg ave. It also can do MPH averages. Makes it easier to try a trip at 45 average and another trip at 60 MPH average... that's where I'll need to experiment, if someone else hasn't already done it.
Gremothra
Sep 9, 2015 08:42 PM
dandw2
Sep 6, 2015 03:14 PM
tylewis
Sep 6, 2015 01:07 PM
Tribe
Sep 3, 2015 08:31 PM
Ntety
Sep 2, 2015 08:39 PM
