VTEC A/C
Correction...condensorS. There are two condensors mounted between the rear two wheels between the subframe with fans mounted on each. The A/C lines run along the bottom of the car through the steering rack into the engine bay. Exhaust runs down the middle through the tunnel.
An original twin point I saw once which came with A/C had a condensor mounted in the front wheel well (passenger side).
