R52 Need help removing cabrio rear interior walls
Old Jun 20, 2008 | 05:55 PM
MassMini's Avatar
MassMini
Anyone know how to remove the hard plastic side walls in the rear seat area of the Cabrio? I've removed the following...
  • Small phillips screw under rubber trim next to seat belt hole
  • Small phillips screw in middle of wall
  • Plastic plug clip (hidden when seat back up, revealed when seatback down)
  • Seat bottom (no fasteners revealed with seat bottom out)
...but the panel doesn't budge.
Old Jun 20, 2008 | 06:07 PM
tony1athome's Avatar
tony1athome
Does this help?
http://www.realoem.com/bmw/showparts...55&hg=51&fg=50
Old Jun 20, 2008 | 06:18 PM
big howe's Avatar
big howe
There's another plastic plug clip down near where the seat back rotates. Pull the seat backs out( loosen one bolt from the trunk) and you will see it.
Just looked at the realoem, #11
Old Jun 23, 2008 | 07:37 PM
goblintim's Avatar
goblintim
also, the top has to be down, found this out when i redid my whole stereo system.
Old Jun 24, 2008 | 07:48 AM
MiniDaMoocher's Avatar
MiniDaMoocher
Take out the both the rear seat and seat back.
There are two plastic plugs along the rear panel. The one you mention and another above it near the top of the panel.
Once done, there are three plugs (not sure what these are called) which hold the panel on. They're located in a vertical line near the front of the panel. Grab the bottom front of the panel (below the speaker) and pull towards the center of the car. Should come right off.
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 26, 2015 01:02 PM
xraycat
Aug 12, 2015 02:36 PM
Cal45fan
Aug 11, 2015 03:50 PM
