Hamann Wheels HM4 or PG4
Old Jun 17, 2008 | 09:31 PM
fupac133's Avatar
fupac133
Hi I was wondering if anyone here has the Hamann wheels. If so can you please post your pics and tire size you are running. I am trying to debate on getting 17 or 18 and would love to see the difference.
thanks
jeff
Old Jun 18, 2008 | 03:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
17" and 18" wheels
HAMANN offers three attractive wheel designs for the Mini. The HM4 is a 17" model, which is a handsome one-piece alloy wheel with five spokes, finished in silver, and has the look of a multi-piece wheel. The PG4 design not only looks like it; it actually is a multi-piece wheel. The 18" five-spoke wheel sports a polished lip. Once again a one-piece wheel, but nevertheless boasting an elegant multi-spoke design, we have the ANNIVERSARY I. With its silver finish and its high-gloss polished INOX stainless steel lip on the outer rim flange, the ANNIVERSARY I is available in 18” form, combining great looks with a practical solution as the stainless steel lip is exchangeable and can easily be replaced in the event of damage. Available wheel/tire combinations:
HM4: front / rear 8.0J x 17 Tires: front / rear 215/40 ZR17
PG4: front/rear 8.0J x 18 Tires: front / rear 215/35 ZR18 or 225/35 ZR18
ANNIVERSARY I: front / rear 8.0J x 18 Tires: front / rear 215/35 ZR18 or 225/35 ZR18
Old Jun 18, 2008 | 03:53 PM
minihune's Avatar
minihune
Silver HM4 17x8 et 43mm 24.2 lbs each
Silver PG4 18x8 et43mm 28 lbs each
Old Jun 18, 2008 | 08:07 PM
fupac133's Avatar
fupac133
do you know what size tires are running on the 18's?
Old Jun 18, 2008 | 10:46 PM
minihune's Avatar
minihune
The two tire sizes as mentioned above are
215/35-18 which is very likely in this picture since sidewall is very small and wheel gap is large. This would be good size if you are lowering your MINI.
or 225/35-18 which would be a better size given it is a 18x8 wheel however if you lower your MINI you will have very close clearance using a wider tire and rim combo. This is a good choice if you want better performance tires like Goodyear Eagle F1 Asymmetric or you have stock suspension.
Old Nov 4, 2013 | 06:15 PM
halid's Avatar
halid
Hamann Anniversary Wheels
This is exactly the wheel I am looking for. I know they are no longer being manufactured. Any suggestions how to get a set?
Thanks,
halid
barnoun
Sep 17, 2018 05:04 PM
mikeyb74
Mar 21, 2017 12:30 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
