Will these fit an 07 r56?
Old Jun 16, 2008 | 05:45 PM
SSr56's Avatar
SSr56
I'm thinking about buying these rims, but i'm unsure if they will fit. Anyone familiar with these? i cant find any info as to weight.
I'd like to get something better but i'm on a budget, and in the process of moving.
http://www.discounttiredirect.com/di...=010599%7C2007
I would also get ASA AR1s, i already have some pirelli 205/50/17s from my old cobalt that i could use, but im not sure if i want to deal with 17's again.
I'm driving a cooper s loaner with 16" and they feel real nice, my cooper has 15s
Old Jun 17, 2008 | 12:50 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
http://www.discounttiredirect.com/direct/wheels/mb_wheels/vehicle/viewProductDetail.do;jsessionid=G043LXHJ213sr1SQfJ npQfQRrGBSbSMhz7W4GMJGDkmg1VxhdXywVqWX1ynZKyqGvfS5 M42LgVh3QnSnxmzzg2JylLmv1BFvLnyQC9Smd53LTkJjvNvh6j PQMCpdCq2b!-1456823798!204142241?pc=49241&v=010599%7C2007
Those wheels would likely fit. Expect offset to be +38mm and weight about 21-22 lbs each. You can contact the vendor.
Also worth looking at-
Rota wheels in 16x7 at http://www.fastmini.net/wheels.html
Team Dynamics wheels at http://www.outmotoring.com/mini-cooper-accessories/7-wheels-misc/
But they are not as cheap.
205/50-17 are too tall for the MINI.
16" wheels would take 205/50-16
15" wheels would take 205/55-15
Old Jun 17, 2008 | 04:42 AM
SSr56's Avatar
SSr56
So i would be ok with 38mm offset? i don't want to damage anything.
Old Jun 17, 2008 | 10:49 AM
minihune's Avatar
minihune
Yes, but only if you use stock suspension and tires that are no larger than 24.4" tire diameter.
205/50-17 is too large to fit well- you will be risk for rubbing in the rear over bumps and with rear passengers or heavy loads.
If you ever lower your car you will need small tire diameter sizes due to the +38mm offset. Such as 215/40-17 or 205/40-17- but that would be for later.
For now use stock tire sizes like 205/45-17.
Old Jun 17, 2008 | 11:28 AM
SSr56's Avatar
SSr56
I was thinking of 195/55/16 or or 205/50/16 I plan on keeping everything else stock. Will I be ok with either size?
Old Jun 17, 2008 | 11:41 AM
Alex@tirerack's Avatar
Alex@tirerack
Sure will!
Alex
Old Jun 17, 2008 | 10:42 PM
minihune's Avatar
minihune
Using stock 16" wheels-
195/55-16 is the standard runflat size if you want runflats, not as many non runflats.
205/50-16 is a good non runflat size and will fit fine. There is a good selection of tires. This size is a good street tire, fairly good handling and comfortable.
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
