R50/53 Timing belt
Old Jun 10, 2008 | 03:24 PM
JohnNC's Avatar
JohnNC
Timing belt
Hello We have reached the 72000 mark on an '04 Time for her first tuneup shortly. Question though, at what average milage are people finding timing belts are failing or need replacement
Old Jun 10, 2008 | 04:16 PM
K5Cruiser's Avatar
K5Cruiser
There's no timing belt. It's got a timing chain. Save the money, spend it elsewhere, do some upgrades, but be thankful you don't have to replace a timing belt as routine maintenance like many other cars.
Old Jun 10, 2008 | 05:45 PM
Ancient Mariner's Avatar
Ancient Mariner
You betcha! But take some of that cash you just saved and replace the serpentine belt. Cheap, easy, and money well spent.
Old Jun 10, 2008 | 05:58 PM
craigfsl's Avatar
craigfsl
or put a new pulley on the sc.
Old Jun 10, 2008 | 07:01 PM
Ancient Mariner
Don't think that's an 'S'.
Old Jun 10, 2008 | 07:11 PM
Capt_bj's Avatar
Capt_bj
Serp' belt
If u gots 70k plus, DO replace that serp' belt
did mine last week at 78k and just in time, there was a tear.
Old Jun 10, 2008 | 07:28 PM
Xymox's Avatar
Xymox
So does a DIY exist for the serpentine belt replacement?
Old Jun 10, 2008 | 08:20 PM
sfomini's Avatar
sfomini
Excuse me (or not) for being off topic, but what is this "pulley" that I keep reading about in various threads? As you can tell, I'm a mechanical noob.
Also, since I'm already off topic: if I were going to consider mods, what should I first consider? MCS with SS, DSC, LSD.
I'd love to replace the runflats, but I don't like the idea of just having a can of flat tire spray (or what ever it is called).
Thanks!
Tony
Old Jun 10, 2008 | 08:25 PM
Xymox's Avatar
Xymox
You own a turbo (R56) MINI Cooper S not a supercharged (R53) MINI Cooper S. You don't need to know anymore about superchargers or pulleys.
Old Jun 10, 2008 | 08:38 PM
sfomini's Avatar
sfomini
That was wierd! I just saw your link to the How Stuff Works article (THANKS!) and when I clicked to quote you and reply, the text was different! You must have posted a correction/edit.
Anyway, thanks for the url, I did read through it and feel slightly less ignorant!
Tony
Old Jun 11, 2008 | 07:11 PM
Ancient Mariner
As for replacing the runflats: A small bottle of Slime and a small 12 volt compressor fits nicely in the back and works great. And the best part: you get rid of the runflats!
Old Jun 23, 2008 | 07:40 PM
beemer2002's Avatar
beemer2002
Back to the timing chain, what is the recommended mileage to replace?
Old Jun 23, 2008 | 08:42 PM
Ancient Mariner
60k is a good place. The belt's around $30, the job's around 20 minutes. The tool is the pricey part, tho you may be able to rent one.
At 72k, you're overdue.
Old Jun 23, 2008 | 09:15 PM
Hound_va's Avatar
Hound_va
That's not a good recommendation for a timing chain replacement. Maybe for a serpentine belt, but not for a timing chain.
Old Jun 23, 2008 | 09:19 PM
Ryephile's Avatar
Ryephile
Um, never unless there's a problem with it. If you need a number, then every quarter million miles is probably pretty close.
Old Jun 23, 2008 | 09:29 PM
Ancient Mariner
Sorry. Missed the 'chain' part.
The timing chain components seem to be pretty bullet proof on this engine and I wouldn't even bother to think about it. Ryephile's number (250k) is probably as good as anything.
Old Jun 23, 2008 | 10:19 PM
Eric_Rowland's Avatar
Eric_Rowland
But you'll want to R&R the SC @ 100K or sooner (if you have an S) to make sure you still have lube in the water pump gear chamber.
bjcarter2
Aug 31, 2015 04:03 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
