M7 Strut Reinforcement plates or STB?
Old Jun 6, 2008 | 09:57 AM
jontalk's Avatar
jontalk
The strut towers on my 05 MCS are fine and I'm about to put a set of BBS R90s with Falken 215x45/17's on the car. A buddy suggested that before I put the wheels/tires on I add the strut tower plates to prevent mushrooming. Then I read a bunch of threads here and I still can't figure out if it's worth spending the xtra $80 for the M7 STB or to just get the M7 Strut Reinforcement plates.. I'm not into Xcrossing, or racing and not a big modder either, though I do want to protect the strut towers and I have the sport package on the car, also.
Thanks for your unbiased opinions, lol.
Old Jun 6, 2008 | 10:00 AM
tony1athome's Avatar
tony1athome
Are you happy with the handling that you have now?
If you get the STB and decide that it's not adding anything, you can simply remove the bar and still have the plates.
For me, I think the STB does add a bit of stability, but with a Cabrio, I need all I can get.
Old Jun 6, 2008 | 10:03 AM
JIMINNI's Avatar
JIMINNI
Here is a post I made in a similar thread:
Originally Posted by JIMINNI
So you don't run a strut bar? If no, why not? You don't think the shock towers can use some help in being braced? And just about any performance car out there has them from the factory, they must know something. Geeze, we looked at a new Toyota Solara yesterday, even they use one. I had a strut bar on my 1981 VW Scirocco, back in the "old Days" .
Old Jun 6, 2008 | 10:18 AM
tony1athome
The contrary argument is that Mini is different. Given the short distance between the towers and the firewall, there is a very minimal lever arm already. Thus the ability of the towers to flex is relatively small to begin with.
Old Jun 6, 2008 | 10:54 AM
Big Daddy's Avatar
Big Daddy
I prefer the STB just because of the extra lateral support. I think it made a big difference in my roll-over. Be aware tho that you will likely have to remove the bonnet insulation to prevent the (M7) STB from deforming the hood closure.
Old Jun 6, 2008 | 11:13 AM
#20Works4me's Avatar
#20Works4me
Hmm not that this is good advertizing for Dinan, but when I removed my Dinan STB to transfer to my 06 MCS from my 02 mcs 1 tab of the 3 mounting points (the same one on each side) had broken, I'm assuming this was caused from a reasonable amount of flex? I did get the tabs welded back on again btw and I noticed an immediate difference when I added the STB. Never had any mushrooming problems on my 02 MCS with the STB after 60,000miles and 35 series rubber on 18" rims, and currently none on my 2006
Old Jun 6, 2008 | 11:42 AM
irieman's Avatar
irieman
FWIW- I have the M7 STB and while it could be all in my mind, I swear I can tell the difference when its on or off.
Old Jun 6, 2008 | 02:35 PM
jontalk's Avatar
jontalk
Thanks guys.. I have to say I'm still on the fence though it seems logical to get the STB.. I think M7s reinforcement plates look better than Cravenspeed and attach with the factory nuts/bolts, as you all know. I'm not going to go to 18" wheels and am hoping the 215x45x17s will fit, though many NAMers seem to run this size without problems. I'm not to hip on removing the hood insulation to fit the strut though.. Oh well. More feedback is certainly welcome..
Old Jun 6, 2008 | 02:39 PM
kenchan's Avatar
kenchan
when it bends it'll bend with the mushroom kits. i dont use one and
haven't had any issues since owning this car back in 03.
tires ive used are 205/45/17RF's (originals that came with the R90's when
i bought the car), 205/50/16, 215/45/17.
Old Jun 6, 2008 | 02:42 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Ken, how many potholes have you bottomed in at speed? Just curious...
I've driven my car hard for 36,000 miles with some awful high speed highway pothole bangage... and no mushrooming, I think thanks to the M7 plates... know other folks with similar experience, but no plates, who did mushroom...
Old Jun 6, 2008 | 02:51 PM
jontalk's Avatar
jontalk
It sort of makes me wonder also.. My 05 has 22.5K and no mushrooming, though roads are pretty good around here.. To be honest, I'd prefer to spend the money on something other than reinforcement plates, but in theory, they make sense since this issue seems to be widespread with all Minis..
Old Jun 6, 2008 | 02:52 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Rollover That's a good reason, but I'd say you would be fine without the bar. I have the M7 STB system and love it, but doesn't sound like something you would see any gains. Plus should you start AutoX or Track and want the bar, you could always sell the caps on NAM and buy a new STB system.
ej
Nov 17, 2015 09:21 PM
vargasgal
Sep 17, 2015 10:02 AM
Sep 11, 2015 01:15 PM
USA-RET
Sep 8, 2015 01:50 PM
Suspension Products
Sep 3, 2015 09:41 AM
