Will These Fit
Old May 21, 2008 | 07:17 PM
youngw682eni's Avatar
youngw682eni
Will These Fit
I currently have 17" black rotas on the car and I am looking to get s-lites, just like the look of them. I just recently got the DT BBK, which fits perfectly with the current rims. I want to know if the brakes fit under the s-lites? any pics would help also.
Old May 22, 2008 | 09:29 AM
Wake|MCS's Avatar
Wake|MCS
I'm not entirely sure but you'll probably need like a 3-5mm spacer to clear the BBK.
Old May 22, 2008 | 10:22 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Why don't you ask Detroittuned? They might know.
It's likely to fit OK since the S-lyte is a standard MINI wheel.
Using a small spacer would give you a little more clearance for the caliper but only for the fronts. 3mm spacer would not require longer bolts or studs. Hopefully you won't need it.
You can also try a fitment test if you have a local MINI club with any owners that have S-lytes. You can try out the wheel since you have your BBK installed.
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
