R50/53 Spec Tech
Old May 17, 2008 | 09:07 PM
amg56aaf's Avatar
amg56aaf
Spec Tech
2004 Mini Cooper S
Performance & EfficiencyHide-
1,598 cc 1.6 liters in-line 4 front engine with 77 mm bore, 85.8 mm stroke, 10.6 compression ratio, overhead cam and four valves per cylinder
Premium unleaded fuel 91
Fuel economy EPA highway (mpg): 37 and EPA city (mpg): 28
Multi-point injection fuel system
- 9.2 gallon main premium unleaded fuel tank
Power: 86 kW , 115 HP SAE @ 6,000 rpm; 110 ft lb , 149 Nm @ 4,500 rpm
Handling, Ride & BrakingHide-
Four-wheel ABS
Four disc brakes including two ventilated discs
Electronic brake distribution
Immobilizer
Spacesaver steel rim under body spare wheel
Strut front suspension independent with stabilizer bar and coil springs , multi-link rear suspension independent with stabilizer bar and coil springs
Old May 17, 2008 | 10:20 PM
Ancient Mariner's Avatar
Ancient Mariner
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
tEckniks
Sep 29, 2015 11:20 AM
krohm
Sep 28, 2015 12:16 PM
gnhovis
Sep 28, 2015 10:56 AM
