18 x 7.5 with 48 offset.... would this fit?
Old May 13, 2008 | 11:27 PM
moji2006's Avatar
moji2006
I found a set of wheels and really like them... but i don't if they're gonna fit or not with that 48 offset... would it fit ?
thank you.
Old May 13, 2008 | 11:34 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You will be fine.
Stock 18" MINI wheel are 18x7 et 52mm, 205/40-18 tires.
You will be only a little wider (10mm= 0.4") and only a little deeper (2mm= 0.1")into the wheel well with that offset.
The mounted tire will be about 4mm or 0.2" farther out from the wheel well.
Old May 14, 2008 | 04:13 AM
PGT's Avatar
PGT
you'll have to run a skinny tire to clear. do you have stock suspension? that makes it more likely to work. a 7.5ET45 with 215 width is tight on a car with coilovers. worst case though....a $30 set of 3mm spacers will fix things if you're too close on the inboard side.
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
