215/45 on a 17x7.5 +45 wheel... no rubbing?
Old May 12, 2008 | 08:37 AM
mini_macky's Avatar
mini_macky
car is a 2004 MCS on stock sports suspension plus + Eibach Lowering springs. should i just go ahead with the 215/45? or go 215/40? 205/45 is also an option but there are very limited brands with this size
Old May 12, 2008 | 10:51 AM
kyriian's Avatar
kyriian
shouldn't be a problem, i ran exactly the same combination before with rota subzeros 17x7.5, 215/45-17, eibach springs, no issues
Old May 12, 2008 | 12:29 PM
MiniEnvy's Avatar
MiniEnvy
Would this be the same for and R56?? I plan on buying 17's and 215/45 and eventually getting the lowering springs as well.
Old May 12, 2008 | 12:34 PM
Guest's Avatar
Guest
R56 has more suspension clearance, so yes, it should be. Wheel offset is key, if the offset is too little (Et38 or so) then the outside edge of the tire will be rubbing on the fender trim.
Mach V springs don't lower the car enough for wheel clearance to be an issue.
Old May 12, 2008 | 09:43 PM
mini_macky's Avatar
mini_macky
215/45 will ride higher than 205/45 correct?
kyriian, got a pic of your Mini with your old setup? so i can have an idea of the gap between the tire and flares and how high the Mini will be from the ground
Old May 13, 2008 | 08:03 PM
Boxcars's Avatar
Boxcars
kyriian
are any of your gallery pics of the above mentioned setup
17's with 45 aspect and lowering springs?
i'm about to do the same , didn't seem like rubbing would be an issue?
boxcars
Old Jul 23, 2008 | 07:05 AM
mini_macky's Avatar
mini_macky
reviving this thread!
now i'm planning to switch from a 17x7.5 +45 rim with 215/40 goodyear F1 TO a 17x7.5 +40 rim with my existing tires
still lowered on eibachs, got h-sport rear lower control arms
will i rub?
Old Jul 23, 2008 | 07:13 AM
kyriian's Avatar
kyriian
Originally Posted by Boxcars
kyriian
boxcars
my bad, here's a pic:
Old Jul 23, 2008 | 10:37 PM
Boxcars's Avatar
Boxcars
looks gooooooooooooood!
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
Chibi2
May 19, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
Carwash
Sep 15, 2015 02:02 AM
