Dragon Run Special - in the DC region
We are still offering the Dragon Run Special Service for all registered DC Metro MINI club members for $265.00, a savings of $180!
The Dragon Run Special Includes;
Undercarriage
Change oil and oil filter while engine is at operating temperature.
Check transmission for leaks.
Half shafts: Check for leaks.
Visually check fuel tank, lines and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads.
Examine brake disc surfaces. Grease wheel centering hubs.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check brake system for leaks, damage,
Visually check shock absorbers for leaks.
Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern.
Rotate all four road wheels.
Engine Compartment
Read out diagnostic system.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Check level of brake fluid in reservoir.
Check windshield washer fluid level.
Check air conditioner operation.
Body/Electrical Equipment
Check battery.
Check lighting system, i.e., headlights, fog lights, parking, back-up, license plate, interior, glove box, illuminated make-up mirrors, and luggage area lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check windshield and tailgate wipers and washer systems; wiper blades, washer jet positions.
Check condition and function of safety belts.
Check central locking system.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, automatic transmission.
Call us at 703.544.0015 or email wayne@funktionauto.com to schedule your appointment today! Please have your DCMM credentials to redeem this special pricing.
Undercarriage
Engine Compartment
Check battery.
Final Inspection
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
flredmini
Sep 3, 2015 07:15 PM
