Suspension Rear Sway Bar Question
Old Apr 24, 2008 | 05:01 PM
revray's Avatar
revray
From all I've read, I've decided that I would like a rear sway bar. Someone has a new factory rear sway bar from a 2005 MCS that has not been used. It includes the OEM bushings and brackets. Can anyone tell me if it would fit on a 2003 Cooper? If it would fit my R50, then I'd like to buy it, but I don't know about these kinds of things.
Old Apr 24, 2008 | 05:23 PM
par724b's Avatar
par724b
sway bar
From all I read and remember from doing mine (my 03 Cooper and then my 06 S), yes it will fit any Cooper or S 03-06.
I would suggest that going through all the work of changing it you should go for a heavier (after market) bar. They usually run under $200. I installed the Mini Madness 22mm bar and love it!!! If your deal falls through and you still want just the S bar I have the one I removed with maybe 1000 miles on it.
Blake
Old Apr 24, 2008 | 05:35 PM
lhoboy's Avatar
lhoboy
The stock rear bar will probably work better for you than a larger aftermarket bar if you don't currently have the sport suspension.
If you would like to add a sport suspension I have one with 28,000 miles on it (installed a JCW suspension in its place). PM me if interested.
Old Apr 24, 2008 | 05:36 PM
wildcrazy442000's Avatar
wildcrazy442000
I had the sport plus rear sway bar (S rear sway bar) replaced on my MC. I went with the H-Sport 19 mm, $288 installed made a world of difference.
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
