StopTech Stainless Steel Brake Lines Now Available For the R56 2007>> MINI Cooper
StopTech Stainless Steel Brake Lines are now available for the 2007>> R56 MINI Cooper and S. StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by reducing the expansion that is allowed by stock rubber flex lines. This provides a quicker pedal response and allows the driver to maintain consistent brake pressure and precision brake modulation. Get more secure braking from one of the leaders in braking performance.
StopTech brake lines consist of a Teflon® inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing.
All StopTech Stainless Steel Brake Lines are DOT (United States Department of Transportation) compliant and 100% tested to a pressure of 4500 psi.
(Not actual product in photo)
Click here to order R56 FRONT brake line set
Click here to order R56 REAR brake line set
