Solo Understeer - Need advice
I'm a recent addition to the autocross community in my area. I spent my money on adding HP initially, and upon entering the world of autox now see that my money might have been better spent elsewhere. My suspension is stock and I'm looking to do a piece at a time as the money becomes available, so the question is this: I'm running Falken Azenis 215/40/17 and I'm getting quite a bit of plowing/understeer at the limits. What would be best to get the front end planted and back end rotating a bit (I want predictable oversteer)? I thought about camber plates to get more bite in the front and playing with tire pressure - also considering rear sway bar, but I want to make sure that I'm not setting myself up for disaster on high speed twisties with scary oversteer problems. What's the best first step?
On a seperate note (if anyone has any advice), I have 190 hp and no limited slip which seemed to be a serious handicap on this months course as I couldn't get the power to the ground. Anyone know a cheap way to get a limited slip, ha ha? Anyone racing street mod like me with no lsd, and if so how are you doing? My thinking is that I need to be carrying as much corner speed as possible since my exits aren't going to be stellar minus the lsd, which is why I was thinking that getting the back end to come around would help - it also may help me to straighten the wheel sooner making for better power to the ground. Thanks for the advice!
Oh, by the way - 2007 S Cabrio, CAI, 15%, One Ball, 380cc injectors, Jan tune if any of the helps!
Adj. rear swaybar, Adj. camber plates/Koni Sport Shocks (yellows) or Cross coilovers, Hoosiers A6 or Kuhmo 710 tires.
I have the H-Sport Comp. bar on full stiff, IE fixed plates & the yellows. No problem with oversteer on the street. I have a hole drilled in the frame rail to adjust the rear shocks for street use, full stiff pogos too much for me and removal to adjust them became a PITA.
The cabrio probably wasn't your best choice for autox-ing, especially if you don't have a triangulated rollcage. You need to stiffen up your chassis. In addition to the recommedations of chuckt, you need to install front and rear shock tower braces.
You can do the following to improve the ability to get that power to the ground...try disconnecting the front swaybar (FSB) (one side is all thats needed), this will allow the front end to roll independently and keep the inside front tire planted better. This costs nothing to do and is effective. Adding front camber plates is alittle costly but is money very well spent. Combining the camber plates and disconnecting the FSB will give you the best result in inside tire grip. Adding an adj. RASB will dramaticly change the dynamics of the suspension durring cornering and will completely remove all understeer. The RASB is the best thing (and is very affordable...I'm using the Alta 22mm with excelent results about $200) you can do to improve day to day and track driving handling. These mods are all allowed since the 15% pully puts you straight into SM class. I have my RASB adjusted for slight oversteer and I use tire pressure to regulate how much oversteer I want (tight course more oversteer loose course less oversteer). I do alot of throtle steering on course and find a twitchy back end is better than none. You could adj the RASB for slight understeer (so you can be safe on the high speed sweepers) and fiddle with rear tire pressure to remove the understeer for autocross...it comes down to what you personaly are comfortable with. I hope this info helps you ...any other ?s just post them here and someone will answer them.
Happy motoring
Happy motoring
Thanks for the responses so far and i think that the sway bar is the best first step - camber plates and possibly shocks later to come, along with chassis braces or strut braces.
I will say though that I hear that about the cabrio a lot though, and while I'm sure that some chassis regididy is missing MINI spent some time addressing this from the factory - there is a large v shaped chassis brace underneath the car as well as front strut tower braces. I'm autoxing for fun mostly anyway, but in my area the fastest times of the day are always the same guys in miatas and S2000's, both the convertible variety. And looking at the gross weight of both the difference isn't substantial enough to make my car uncompetitive in my opinion.
I'll welcome any input on the subject though and I do appreciate the advice so far. Would disconnecting the front sway bar introduce a lot of body roll into the equation? It would seem that without stiffer springs this might not be the hot ticket, but I'd love to hear about any experience with this.
that's where I'm going first. I see that everyone likes the H and R 19mm adjustable but I can't find anywhere to buy it - got any suggestions?
You can certainly stiffen up the chassis with the M7 chassis products.
http://www.m7tuning.com/parts/index.php?cPath=7_2
Though stiffing the chassis is a good idea overall, it will probably tend to increase understeer if anything, handling wise. I think the M7 stuff mostly effects the front end of the car, and that money should go to more effective mods IMHO.
I might try the FASB disconnect trick though. Several GStockers have gone to the Cooper bar up front with success also.
unhooking the front bar takes away everything that is good about the handling of the MINI.
To decrease understeer you have three options, increase front grip (add camber), decrease rear grip (stiffer rear sway bar), and fix the loose nut behind the wheel.
Ultimately, if you have too much understeer, you entered the corner too fast. With a front drive car you cannot completely eliminate understeer. With proper tuning, you can reduce it, but the worst driver can make any car push...
...and fix the loose nut behind the wheel.
I got rid of my M7 braces long ago and am running a TSW x-brace. The S2000 is incredibly ridgid due to an 'x' style brace and the fitment on the TSW is worlds better than the USS.
Thanks for the input. I've been thinking about an undercarriage brace.
understeer
DON'T disconnect the front sway bar! Big mistake. This will create more roll and put more weight on the outside tire which = less weight on the inside tire. What does that cause? More wheel spin. Motoring is right. Your coming into the corner too hot, this increases the push condition that your experiencing. Remember: Slow in, fast out. Early in, early out. This especially applies to a front driver. Another thing you can do is to put a different tire on the rear. The Hoosier A-spec (for autocross ) for the rear and the Hoosier R-spec (Race) compound up front has worked for many guys. I know a guy who will be running the autox at MOTD who runs that same set-up. The only guys faster than him at his last event were 2 Vettes, and only just barely. You will have to play with the tire pressures until you find what you like, and remember; sun, temp. and humidity all help determine your pressures, the same pressure will not work every time. Start with a baseline and go from there. Keep track of all the factors and pressures, and with time you will find what works best. Those Miata's and S2000's are better handling than your Mini, you have to use your skill and cunning to beat those dastardly dudes!
). First place in street mod is a supercharged miata, and second a 400hp supercharged mustang. I honestly think though that with the correct setup in suspension that a better driver than I could be competing with these guys though. Fastest Pax for the day is a miata in STX (man that guy is good - he almost always wins pax). It's good to have a dialogue going about suspension as there are many opinions and lots seeking advice!TSW doesn't recommend a bar that big in the back...especially for a street car. 22mm is a better/safer way to go. Also keep in mind...there's no free lunch. A stiffer bar always means less independent articulation which also means less traction over less than perfect road surfaces.
we've yet to see proof of this in timeslips, but it sounds nice
How are you liking the 22mm at the track. Are you able to get any rotation at slow speed? Just curious how you like it compared to the H Sport
everything is different on my car...hard to compare as the bar went on with everything. old setup was PSS9's, 19mm H-Sport and RE01R's. Current is Cross, 22mm RSpeed and ZIEX912. I'll get the RE01R's back on next month when the new wheels arrive.
Okay, here's an update from the Detroit Tuned Site - the H-Sport competition bar is a hollow 25mm bar, which is effectively a 22mm solid bar so in the end the torsional resistance should be the same unless I'm misreading this. So, I should be still on the safe side for the street
How do you like the Cross coilovers? Adjustability? spring rate?
