NEW WHEEL FROM ALTA & PIAA
NEW FROM ALTA MINI PERFORMANCE
ALTA MINI Performance is proud to announce the NEW Euro Tech Vintage wheel from PIAA Corporation. It is a new take on a vintage 8-Spoke MINI Cooper design available in 17” diameter instead of the vintage 13”(haha). The wheel is a one piece pressure cast that is up to 20% lighter than your OEM 17’s (17lbs) to translate more of that power into forward momentum or the brake force into stopping power.
The Euro Tech Vintage wheel will accept the OEM tire pressure sensors and both 12mm and 14mm lug bolts.
The finish is a bright silver called Racing Buff Finish.
Size/Specs: 17 x 7.0, 4-100, et40
There are so many wheels out there that it is truly hard to find one that your neighbor wont have on his Honda Civic. So be different and bolt on a set of this rare wheel and really have a unique looking MINI.
We have the entire first production run allocated to us!
So Get’um while they’re HOT!
$1100.00 for a set of four. Includes freight.
Click HERE to order or to check them out!
Wohnson89
Jun 10, 2020 04:53 AM
