Suspension RECS needed: front control arms
what have you done w/ the car? what are you looking for in terms of performance? i added Alta's PSSR (relocated, stiffer lca bushings to add caster). my car has a fairly aggressive alignment and was bordering on "twitchy". the car is now much more stable in a straight line and in high speed sweepers. i like this mod both on the track and on the street.
OEM front control arms are more than adequate for even spirited street use. ideally, a good alignment should follow the addition of lowering springs. control arms only became an issue for me after completely changing the MINI suspension.
I was told about the MINI-Madness front control arms, but at $799/pair, I just wanted to make sure that it was a "need" instead of a "want".
I've decided to stick with the OEM control arms.
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
