""THE LIGHT BAR BLOWOUT"" Palo Uber Mini.com
Old Mar 14, 2008 | 11:22 AM
Carol@PaloUberMini.com's Avatar
Well we just recieved our order, and got double shipped.......
SO we have 4 of the Original Uber LIGHT BAR KITS for NAM Members only, saving you $$ 125.00 ....On the 2002-2006 application.
THE LIGHT BAR by Palo Uber Mini London is laser cut stainles steel and robotic welded, then powder-coated in stealth black. We continue to ship this product world-wide.
Each kit comes to you with our professionaly made wiring harness , with all connectors "already" attached, all fuses and relays "already" installed, all lengths pre-cut and the entire wiring harness is fully wrapped and bound for a moisture resistant component. Each faceplate is also powder-coated and tucks in under your toggle row.
Unlike others, our system does not depend on other lights being illuminated to operate, but instead is completely independent, allowing you to activate two or all four driving/fog lamps at any time.
Unlike others, ours is still the only mounting bar which is "completely" concealed inside your lower dam, which not only provides that concourse look, but actually allows superior visual clarity due to the lamps low location to the road surface.
THE LIGHT BAR, by Palo Uber Mini London is the original concealed light mounting bar, providing that absolutely essential ability to clearly see where you are going regardless of the climactic conditions you may encounter.
PHOTOS: go to www.paloubermini.com and click on the online store catalogue. Click on the online store photo for additional images and information, and also find images on our "gallery" section to scroll through.
TO PLACE ORDER: go to www.paloubermini.com and click on the online store catalogue, then simply scroll to locate page four, and execute your order for
NAM KIT # 3......fits all 2002-2006 applications
THE LIGHT BAR for the R-56 has also arrived, and can be seen on our online store catalogue also.
We thank you for your valued business and support....Reicher, Palo Uber Mini California
Aug 12, 2015 01:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
OutMotoring
Aug 6, 2015 09:32 AM
