Drivetrain Ported and Polished my TB
Old Mar 11, 2008 | 06:26 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
Blu Bal was down and so I decided to port and polish the TB since it was off the car, and knife edge the butterfly valve.. Took about 2.5 hours total.
Realized I forgot to take final pics before installing.
I took enough pics in case I wanted to do a DIY write up.
Old Mar 11, 2008 | 06:29 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Do you notice any difference?
Old Mar 11, 2008 | 06:35 PM
Big-Daddy-Blue
I did. It seemed to rev easier and wants to move off the line faster. But what does the butt dyno know right?
Old Mar 11, 2008 | 06:43 PM
AstroBlackS's Avatar
AstroBlackS
Thats awesome! Way to take a DIY initiative! It's all about the butt dyno because when it comes down to it, it's you driving the car! Not a dyno.
Old Mar 11, 2008 | 06:45 PM
Big-Daddy-Blue
I'll do a write up and post it if people want me to.
Old Mar 11, 2008 | 06:53 PM
RussellCory's Avatar
RussellCory
YES!
Old Mar 11, 2008 | 07:30 PM
minimarks's Avatar
minimarks
Old Mar 11, 2008 | 07:43 PM
Some Guy's Avatar
Some Guy
Please do!
Old Mar 11, 2008 | 08:33 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Is it easy to do? I mean, can you permanently damage your throttle body if you mess up? I might be intersted in the process.
Old Mar 11, 2008 | 09:27 PM
kapps's Avatar
kapps
Anything that involves removing a finite amount of material that can't be replaced means there is a possibility of permanent damage. When it comes to porting heads at least, lots of practice and flow bench testing is involved. I'm sure the TB is a little easier since it's just a single circular passage. I'd love to see a writeup.
Old Mar 11, 2008 | 11:50 PM
Bang110's Avatar
Bang110
Writeup! Please. I would give this a try if it seems like something I could manage.
Old Mar 12, 2008 | 07:03 AM
Kentiki's Avatar
Kentiki
+1 here on seeing a DIY. That would rock.
Old Mar 12, 2008 | 07:07 AM
BlimeyCabrio's Avatar
BlimeyCabrio
+ a zillion.
I'm also VERY curious - as the self-appointed NAM grand-poobah of whistling throttles...
a) did this car exhibit any throttle whistle at slight open throttle before the mod, and
b) if so, did that change at all?
Old Mar 12, 2008 | 08:13 AM
Big-Daddy-Blue
you are correct. there is a a critical part when grinding close to the butterfly valve. If you got to far, then you basically open the space around it more and create idle problems.
Old Mar 12, 2008 | 08:14 AM
Big-Daddy-Blue
Originally Posted by BlimeyCabrio
+ a zillion.
I didn't notice any whistle. I am running a 19% pulley, Alta drop in filter, DT BPV.
I did notice I get more blower whine now and low rpm.
Old Mar 12, 2008 | 08:15 AM
Big-Daddy-Blue
Give me a few days to get this write up guys and I will post it up.
Old Mar 12, 2008 | 08:31 AM
Fini's Avatar
Fini
What measurements did you use for the modification? Write up, please!
Old Mar 12, 2008 | 08:38 AM
Big-Daddy-Blue
measurements for?
Old Mar 12, 2008 | 11:30 AM
k-huevo's Avatar
k-huevo
There are three styles of throttle body modifications, full bore with enlarged plate, double venturi, and venturi at entrance, Stephen’s appears to be a semi-double venturi. But, the flow path downstream of the TB is to be considered if you think modifications of this type have much worth beyond self gratification, if you’re not making other wholesale changes. The entrance to the supercharger intake duct is 62.6mm ID, 4.6mm larger than the TB bore, discussions about protuberance created by the plate post can support either pro or con argument of effect but we’ll keep this simple and use ID or fluid diameter for comparison, so were ok for the first .75 inch, then the effective diameter/fluid diameter narrows a little more, still ok until a few inches later it drops to less than 56mm. The fluid diameter of the section on the left in this photo is smaller than stock bore.
A segmented supercharger intake duct reveals a variety of fluid diameters which don’t exceed 62mm until an inch before the outlet side and there is a ramp at the end (removed in this example) which effectively narrows it again.
Forced induction will overcome variances in the upstream/downstream flow path that are detrimental in naturally aspirated applications, but upstream can only flow as good as its narrowest section. It’s hard to let go (I’m big time guilty) of NA notions if that’s what you’re experienced with. Our intake tracts (including TB) have proven to be good for lots of output.
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Aug 6, 2016 07:19 AM
flpat73
Nov 2, 2015 06:38 PM
micromini234
Sep 30, 2015 07:36 PM
Sep 2, 2015 11:15 AM
