MotoringSpeed and RMW Create 230 HP MINI
Old Mar 10, 2008 | 04:29 PM
MotoringSpeed_gnat's Avatar
MotoringSpeed_gnat
Stage 1 of MotoringSpeeds 1st Project Car has been successfully completed. With only 3 hours of tuning on AutoScope's DynaPack dyno Jan of Revolution MINI Works found quite a bit of power. The MINI, a bone stock 04 example with ~ 24K miles on the clock was transformed into a tire smoking Chesire Cat sized grin producer. Three weeks from concept to reality with Will of Bob's Tire and Auto in Lewisville, TX deftly handling the mechanical end in a scant 6 days.
A baseline dyno at the beginning of the project in cooler weather netted 147.7WHP at 6307RPM with 148.5Ft/lb at 4051. A quick base flash was installed to scale the 440cc injecters to prevent fouling of sensors during the trip to the dyno. The first pull returned 207WHP and 162Ft/lb. Capable tuning yeilded a final result of 230.5WHP at 7414RPM and 184.1Ft/lb at 4872RPM. What the numbers, as impressive as they are, do not show is the 170+ft/lb available form 3200-7100RPM. See the scan below.
Mods:
RMW Head
RMW Cam
RMW Adjustable Cam Gear
RMW Header
RMW Exhaust
ARP Head Studs
440 Injectors
CravenSpeed CAI
CravenSpeed 15% Pulley
Quaife
ClutchMasters Stage 3 Clutch
Old Mar 10, 2008 | 04:50 PM
PGT's Avatar
PGT
nice numbers. what's the benefit of the cam gear? that's teh one thing we didn't do on my (besides the clutch).
Old Mar 10, 2008 | 04:55 PM
Forcefeed's Avatar
Forcefeed
Can all this be done to a MCSA. Has it been done? Minus the Quaife &
Old Mar 10, 2008 | 05:26 PM
gnatster's Avatar
gnatster
Retarding the camshaft timing will generally shift the powerband upward, increasing top-end power. Conversely advancing the camshaft timing will shift the powerband downward, allowing for increased torque at lower RPMs. However since we are supercharger speed dependent and the S/C does not really come into play until around 3K RPM advancing the camshaft is somewhat useless on an MCS.
Old Mar 10, 2008 | 05:37 PM
jhiggs26's Avatar
jhiggs26
Benefit=precise custom cam timing and ability to alter cam timing(advanced or retard) fairly quickly. With no adjustable cam gear we are limited to rotating cam/timing chain from sprocket to sprocket right? The adjustable cam gear will allow infinite adjustments between sprockets.
Jeremy
Old Mar 10, 2008 | 05:57 PM
Chappy's Avatar
Chappy
Nice, very nice.
Hey, I live in Texas... can I get one of these???
Nitrominis's Avatar
Nitrominis
Nice thoughts about cams jhiggs I have read a couple of your comments around...you have a MINI now not a Detriot Hot Rod !
I may be wrong but having an adjustable cam gear is great if Jan is going to be around to re tune after making any cam timing adjustments. I would think the purpose on the MINI engine is during Dyno/Tunes to play around with adjustments to find the optimum cam timing for a given RPM operating range. It is kinda like changing cams only not. Any changes in that area effects the final tune I believe. At least on every other engine out there. I used them on DETROIT steel long ago before ECU's
Old Apr 1, 2008 | 01:14 PM
70spop's Avatar
70spop
Regarding advancing the cam for more low-end power, I was just wondering if a faster closing bypass valve, ie the Detroit Tuned one, would make any difference in the equation. Obviously it doesn't affect the s/c speed, but would the fact that it closes faster and therefor helps the s/c start producing boost faster help with an advanced camshaft making more torque down low?
Old Apr 2, 2008 | 10:46 AM
checkers's Avatar
checkers
Forcefeed yes. I have every thing in my car, but I have a 17% pulley & a 2% crank pulley. I'm running 380 injectors. The problem is getting the car to stay in gear long enough. Mine has been upshifting at 6500 rpm's, so the numbers are a little low. Jan's working on it.
Old Sep 11, 2009 | 05:51 PM
flatlander_48's Avatar
flatlander_48
Obviously people think differently about this than I do, but I would question the idea of doing all of this work with an automatic behind it. If they beefed up the 6sp manual in the JCW for a 36 horsepower difference, I would have to wonder about the life of the Aisin automatic when backing up big power...
Old Mar 29, 2011 | 12:05 PM
thebestbear's Avatar
thebestbear
Our auto S was pushing 201 whp and I think that's all that I would be willing to put to that transmission. Not to mention there is no posi in it, so you can't use the power low end anyways.
Old Sep 9, 2011 | 08:33 AM
jakesulivan's Avatar
jakesulivan
Thats a nice suggestion. You have got real knowledge for these things.
MiniJess
Aug 10, 2015 09:51 PM
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Dashdog
Aug 10, 2015 06:17 AM
M7Speed
Aug 6, 2015 01:48 PM
