Navigation & Audio Replacing HK Head Unit
I have an 05 MCS with H/K, mfsw and the factory iPod integration. I am not really happy with the limited functionality of the factory iPod adapter. I would like to see the songs on the screen and be able to control the ipod from the stereo and the ipod. I have the iPod Touch, so it would be nice to hear audio from videos as well. So, I am debating on whether to get the DICE adapter or get a new head unit. If I got a new headunit, I would look for one with built in ipod integration and bluetooth, but would still want to be able to control it with the steering wheel (at least the volume and up/down).
I was looking at crutchfield and the only wiring harness they sell is a bypass harness, which would require running wires directly to all speakers, bypassing the h/k amp. I do not want to do this. I know that newministuff.com sells the adapters I need, just not sure what ones I need to get. I have read many posts and am still a bit confused. Could I get some help please?
The enabler that you need is this...
http://www.newministuff.com/new/shop...uctshow&id=116
The mode adjust model lets you select the different pre-selects like electronic, H/K, etc...
If you have questions, you might want to send Mikey an e-mail.
Do you have OEM NAV?
I would get the DICE and keep the HK. If you are happy with the HK's performance, just keep things simple and get a good iPod adapter. If you are looking to add BlueTooth as well, newministuff.com also has a good kit that works with HK and the MFSW buttons.
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Navigation & Audio help identifying a couple wires
yashmack
Aug 15, 2015 03:11 PM
