""NEW-NEW"" R-56 VISION.....IN STOCK...by Palo Uber Mini.com
Old Feb 23, 2008 | 05:37 PM
Carol@PaloUberMini.com's Avatar
WELL IT'S HERE...It took us over a year in development to bring you "THE LIGHT BAR" by Palo Uber Mini London for your R-56 MINI S "AND" you R-56 MINI S CLUBMAN.........
As before, the bar is "COMPLETELY CONCEALED" inside your lower dam, with only the lamps exposed. And, as before, the Light Bar is laser cut and robotic welded, then powder coated along with the faceplate which tucks in under your toggle row,
ALL connectors are already installed along with your inline fuses and relays.
Our wiring harness is moisture resistant and fully bound for years of uncompromised quality usage.
"The Light Bar", by Palo Uber Mini London is completely assembled on your work bench with the front bumper removed. As before, there is NO DRILLING of steel to mount the bar or to level the bar. Once The Light Bar has been completely installed on your work bench, including mounting the driving/fog lamps, you simply remount your front bumper, then run your wiring harness.
Power is connected at your open station at the fuse box.
THE LIGHT BAR by Palo Uber Mini London is appearing in the next issue of "NEW MINI MAGAZINE" the true Mini enthusiast publication.
The Light Bar will fit perfectly to all 2007 forward Mini S models AND the 2008 Mini S CLUBMAN. We have already installed these units for Alexander BMW MINI, Los Angeles. This system, due to it's height positioning from the ground will provide absolute clarity in any cliamactic road conditions you may encounter. The dual switches allows for two or four lamps illumination, and the switches themselves will only illuminate when your driving lamps are on. Our system allows you to mount only two lamps would you choose to do so.
NAM members save $100.00 while our initial supply lasts, as an introductory special.
SEE PHOTOS: go to www.paloubermini.com and see photos on our online store catalogue.
TO PLACE YOUR NAM PRICE ORDER : go to www.paloubermini.com and click on online store catalogue, then scroll to find NKIT # 1-R-56 and execute your order.
We appreciate your business... Palo Uber Mini, California
mini b
Dec 19, 2006 05:54 PM
