Interior/Exterior removing headlight rings
Old Feb 13, 2008 | 11:36 AM
freeskier's Avatar
freeskier
im ready to remove and paint my silve headlight rings balck. car is an 02 MCS, how should i go about removing those trim pieses? thanks
Old Feb 13, 2008 | 01:35 PM
Shrashmere's Avatar
Shrashmere
you have to take the headlights out of the hood ( three 8mm nuts on each light) and go at it from the back tabs holding the rings on carefully with a screwdriver. there are little pieces of double sided tape holding the rings in place, just tug gently and they will come off. The're stuck in there pretty tight so you will struggle with it a little. I think the tabs you want to pry at are on the bottom, the top ones are different and wont come off.
How are you painting it if you mind me asking?
Old Feb 13, 2008 | 02:12 PM
freeskier's Avatar
freeskier
i have this paint that is used for painting outdoor furniture, i used it on my lower grille trim and it has lasted really well. im going to sand, pryme and then hit it with 3 cats of that and a sealer. how long should this take
Old Feb 13, 2008 | 02:41 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
I didn't have to take the headlights out.
I taped around the ring on the baody to make sure i didn't scratch it.
Gently pry the ring up slowly. You will need to take off the washer piece first.
There are tabs around the ring and some double sided tape. Just be careful and take your time.
Old Feb 13, 2008 | 07:51 PM
joshamman's Avatar
joshamman
be careful of the sticky tape! mine was on so much that i destroyed all the tabs on the bottom of the rings :( you might want to try and slide a thin blade between the ring and the light first, to kill the tape, and then go at the tabs.
dyeLucky
Sep 11, 2015 10:41 AM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
dyeLucky
Aug 7, 2015 07:10 AM
