Key Fob Waterproof?
Old Feb 3, 2008 | 06:29 PM
mooo's Avatar
mooo
Key Fob Waterproof?
I dropped my key in the bucket while washing Charlie =(
Does anyone know if the key will still work? I'm afraid to test it for fear of shorting some of the circuitry.
Old Feb 3, 2008 | 06:32 PM
mooo's Avatar
mooo
This may be a good time to figure out how to access the battery. My keyfob doesn't look like the one in the manual. The back cover doesn't look like it has a smaller section for the battery, but is instead one piece. Has anyone figured out how to do this?
Old Feb 3, 2008 | 06:42 PM
checkercoop's Avatar
checkercoop
Im not sure how to access the batter, but the 1 in the manual i believe is the comfort access...the normal ones are 1 piece...mine is 1 piece...the comfort access has the opening because if they always keep it in their pocket when driving and the battery eventually dies, they will be locked out...the regular ones are always charged so idk if its as easy to get to
Old Feb 3, 2008 | 06:46 PM
OkieSnake's Avatar
OkieSnake
It has been my experience with electronics is that if they get wet, let them COMPLETELY dry out before even thinking about testing them. I would open up the battery compartment and let it dry out a few days. People often can't deal with the wait and "test" them before everything has dried out and THATS when things get ruined. Be patient! Let us know how it turns out.
Old Feb 3, 2008 | 07:37 PM
tag's Avatar
tag
The newer fobs are rechargable and do not have a battery door except for the comfort access system
Old Feb 3, 2008 | 11:34 PM
valthun's Avatar
valthun
place it in a small bucket of clean kitty litter for a couple of hours. That should remove any moisture and you should be good.
Old Feb 3, 2008 | 11:55 PM
OasisT's Avatar
OasisT
And make sure cat doesn't have access. lol
Actually, my wife washed my key when I accidentally left it zipped up in a pocket of my sweatshirt, that was roughly 4 months ago and it has worked perfectly since. I can't remember if the key was also put in the dryer as well, but, I am thinking they must be waterproof. Only one way to find out!
Old Feb 4, 2008 | 04:29 AM
Cabbagehead's Avatar
Cabbagehead
In anticipation of this problem I asked the service department at my dealer and they werent sure but said it would probably work after drying out.
Old Feb 4, 2008 | 06:53 AM
COOP310's Avatar
COOP310
Good Advice!
Old Feb 4, 2008 | 07:05 AM
gokartride's Avatar
gokartride
I believe someone here said they ran theirs through the laundry....and it still worked!!!
Old Feb 5, 2008 | 06:54 AM
lacning74's Avatar
lacning74
I'm tempted to test mine in the dish washer. It's looking dirty.
Old Feb 5, 2008 | 08:50 AM
tag's Avatar
tag
Rinse fob with rubbing alcohol to speed drying.
Old Feb 10, 2008 | 12:11 PM
Babul03's Avatar
Babul03
When I had my MINI in for service, they gave me a BMW 328i. It has a very similar key, and I accidentally dropped it in my dog's water bowl. I'm an idiot, I know. Thank god it worked though. I had no problems with it whatsoever. So I'm guessing yours will be just fine.
Old Feb 10, 2008 | 01:32 PM
daffodildeb's Avatar
daffodildeb
I'll bet BMW wouldn't have been too happy if they'd known!
These key fobs are neat, but ridiculously expensive. I'd dry it out as much as possible, maybe using the desiccant granules you can get at one of the big-box hobby shops. They're used for drying flowers.
Old Feb 10, 2008 | 05:55 PM
Luongo's Avatar
Luongo
My BMW keyfob went through the washing machine and drying machine cycles on two separate occasions and still works perfectly.
Stick your wet keyfob in a khaki pocket and run through the drying machine.
Of course, I am not responsible for any damages...
Old Feb 11, 2008 | 08:53 PM
mooo's Avatar
mooo
Good news. Thanks for all the advice. I grabbed a few packets of desiccant (not from a hobby shop, but from snack packets, lol) and put it in a warm spot for a few days. The key works like new.
It's a little strange that there is no way to access the battery though. Even if it recharges itself, all batteries have a lifetime, and I don't want to replace the whole thing just because the battery died.
Old Feb 17, 2008 | 08:54 PM
danielo's Avatar
danielo
I do believe it's washing machine-proof.
I have had my E46 key in the past gone thru the washing phase in the machine, still worked for years after that.
My Mini's key has been thru 1 comple wash cycle. And it's still working fine.
Old Feb 22, 2008 | 05:05 PM
nikoamok's Avatar
nikoamok
spray it with novatio multi super 5 oil... it remowes moist and protects the keys if you should do that again... i dit it to my cell phone... www.novatio.com
Old Jul 2, 2009 | 02:29 PM
jjshoe's Avatar
jjshoe
Been surfing with my key, worked good after I:
1) pulled the battery immediatly
2) placed in the sun to dry
3) installed new battery
Old Jul 2, 2009 | 03:03 PM
jessicaledw's Avatar
jessicaledw
About a year ago I dropped my phone in a bowl of water and the best suggestion I found on the internet was to put the phone, or other electronic, in a bowl of rice and let that absorb all of the water. I didn't have any rice handy so I just let the phone dry out for 24 hours. I would imagine that the key fob is similar.
Oh, and the phone eventually broke and had to be replaced but it worked for nearly a year after that incident.
Old Jul 2, 2009 | 03:04 PM
sdavid01's Avatar
sdavid01
I've washed mine. I removed the battery and let it dry out. Haven't had a problem since!
Old Jul 2, 2009 | 06:28 PM
blackjackmark's Avatar
blackjackmark
Accidentlaly washed mine, it works, but it does seem like the range is a lot less, even with a fresh battery (mine's Comfort Access)
Old Jul 2, 2009 | 08:05 PM
danielo's Avatar
danielo
How did you guys remove the battery?
Old Jul 2, 2009 | 09:34 PM
daffodildeb
I think that's just for the Comfort Access gang. Isn't it?
Old Jul 20, 2009 | 10:50 PM
juchong's Avatar
juchong
You can only remove the battery on the comfort access key fobs. The regular ones have a built-in battery and charge using inductance when in the key slot. I'd imagine that the regular key fobs are pretty water-resistant with the buttons being the only weak spot, but the comfort access ones might be a bit more susceptible to water damage. IMHO I like the kitty litter idea, or if you need your key fob immediately, find someone with a vacuum pump and a mason jar. Whenever you pull the air out of something you also lower its boiling point (in this case, the water's boiling point) which means that the water evaporates at room temperature!
Bam! Completely dry key in 30 seconds
