R50/53 MINI Talkers: Please Read
This is partially an attempt to clean up all the sticky posts in MINI Talk, and also to clarify some issues related to the forum.
I will address several points in this post
THE SITE GUIDELINES
the full site guidelines are available for you to read. I would like to highlight a couple of areas that we as moderators have had to handle with increasing frequency of late.
MINI Talk is not a dumping ground. Here is the intent of each forum:
Beneath the Bonnet - this is the forum to post your problems with the OEM parts and systems that came with your car. It is *not* limited to engine issues, although there are a couple of significant discussions running in the forum related to those - the engine stumble and coolant.
Performance Mods - this is the forum to post about aftermarket upgrades to your MINI's suspension, brakes, engine/ecu/intake/exhaust, etc.
Interior and Exterior Mods - Things like roof flags, bonnet stripes, and seat covers. NOTE: do NOT post about wheels or audio, we have specialized forums for those.
Tire and Wheel Forum - the Tire Rack has been very active in this forum and it's a real resource for anyone looking for new wheels or tires. Please post those issues in this forum.
If you post doesn't fit into any of the specialize categories (and that is not a complete list) only then does it belong in MINI Talk.
Signature size seems to be escallating on the forum. Please be considerate to others an keep your signature size reasonable.
Here is an excellent example of a good size for a signature image
MCO Search Functions Explained
There are actually three different search functions on MCO. This graphic I put together explains where they are and what they do.
Popular / Newsworth posts in MINI Talk
Posting a Picture (moved to the test forum)
MINIUSA Re: Windshields This is the official post by MINIUSA regarding the windshield cracks. Please post to the thread if you've had problems.
MINI Owners License Plate Registry (unofficial)
1 year: 29004 miles (long term report)
PM A Moderator
One final request. If you have problems with the site, or see something that needs moderation, please private message (PM) a moderator. The moderators for each forum are posted at the top of the forum.
Dave :smile:
THE SITE GUIDELINES
From the site guidelines: Clean Posting
MINI COOPER Online will not tolerate explicit, obscene or vulgar language and will remove any post containing this type of language. Similarly, any post that solicits or offers explicit, X-rated, or similar content will be deleted without notice.
From the site guidelines: Duplicate Posts
Before posting please search for similar subjects. If you do not find information that answers your question, we encourage you to post the question or comment to a discussion forum. Take the time to identify the most appropriate forum and do not post to multiple forums. If duplicate discussions are identified, the duplicates may be consolidated or deleted. Repeated posting of a message may be interpreted as SPAM and deleted without notice.
From the site guidelines: Signatures
Each member has the ability to display a signature, which may include html and images. We encourage you to customize these signatures. We do request that you keep the overall size of the signature as small as possible to insure that article and forum posts can be viewed easily. As with posting, please keep your signature clean.
Originally posted by RandyBMC:
This one is to help everyone take full advantage of all of the information out there on the site.
Tools Required
Fingers
Time Required
1-2 minutes
At the top of each forum, you will see small yellow font words starting with New Topic. Next to that is a search. Click on the word Search. It will open a small menu. Use the keyword you are interested in - for example, ECU. It helps to also pick a forum - for example, Performance Modifications. You can then choose to see posts by a particular member (like me ), or all relevant posts. You can also choose to sort by date, topic, etc. Choose to search for the title of the thread, or all of the words in the thread.
After using it the first time, if you get too much info, you can narrow the search.
I hope that helps!
Tools Required
Fingers
Time Required
1-2 minutes
I hope that helps!
PM A Moderator
Dave :smile:
