17x7.5 wheels on a lowered R56: Ideal Offset?
Old Jan 17, 2008 | 09:37 AM
Wolfgang80's Avatar
Wolfgang80
I'm weighing wheel options. I'd love to find a used set of wheels but I may end up ordering and one of the wheels I'm looking at can be ordered in either ET43 or ET48.
I'll probably end up lowering about 1.5", if that's relevant to the discussion.
Secondly, if you compare two wheels, one 7" and one 7.5" with the same offset, am I correct that the 7.5" wheel will stick out .25" more than the 7?
Thanks for your help.
Old Jan 17, 2008 | 09:38 AM
tomah's Avatar
tomah
it also depends on how much camber and what tire size you are going to run
Old Jan 17, 2008 | 09:46 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
This is correct which also means that it will be .25" wider on the inside as well.
If you're looking at a 7.5" wheel, I'd say go with the et43
Old Jan 17, 2008 | 01:39 PM
Wolfgang80's Avatar
Wolfgang80
On a 7.5" wheel, I'd probably go with a 215/40 tire.
Old Jan 17, 2008 | 02:11 PM
kenchan's Avatar
kenchan
i would do +43 vs +48.
and 215/45/17.
Old Jan 17, 2008 | 03:16 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
and 215/45/17.
The OP mentioned this will be on a lowered R56 so watch out of clearance using 215/45-17 which is about 0.4" taller than stock tires. You may have just enough room depending on how much you lower your MINI.
That's why 215/40-17 was mentioned since it is smaller than stock tire diameter and offers a little more clearance but a little stiffer sidewall means harsher potential ride and less protection from risk of damage to the tires and rims from hitting a big pothole.
205/45-17 is a usable size but tire selection is more limited. 215/45-17 gives good tire selection but is taller. 215/40-17 has good selection but usually is more performance oriented and costs more.
You don't always have much choice with wheel offsets. +43 mm for any wider than 7" rim in your case would be better than +48. If you get a little rubbing you can try to increase rear negative camber a little to gain clearance.
Old Jan 17, 2008 | 03:40 PM
cooldaddy's Avatar
cooldaddy
I run 17x7.5 40 offset, 215/45, and my car sits low, stance is great; but even after dremeling the inside fenders I still get quite a bit of rubbing on larger dips... so an offset of 43 should be better, different tires in the same size can make things better or worse, 215/40 should provide a bit more clearance... I went with 45 series for the extra protection on our bad roads...
Old Jan 17, 2008 | 03:51 PM
ENGINE 58's Avatar
ENGINE 58
man minihune you rock.
Old Jan 17, 2008 | 06:43 PM
Msteadman's Avatar
Msteadman
^^+1!
First mentioned I've heard of running 215/40/17's on a MINI. Tempting... Is anyone else doing this? Also, any negatives other than a rougher ride, more expensive tires and inaccurately faster speedo??? I know it's a significantly smaller diameter tire.
I also have an R56, will be installing lowering springs soon and plan to purchase a set of 17x7.5" wheels. So it relates back to the OP's question while helping me out.
Old Jan 17, 2008 | 06:45 PM
PGT's Avatar
PGT
215/45/17s work great.
here is VoiD's car with 215/40/17
yes, R53's, but R56's have more room if the offset is not too high
Old Jan 17, 2008 | 06:52 PM
Msteadman's Avatar
Msteadman
Sweet! I just love the look of low profile tires. They don't sacrifice any width and the 912's are about the same price in either size.
Question, why is it that 215/40/17 can accommodate a wider wheel over 215/45/17? According to 1010 Tires, the former fits 7-8.5" while the latter 'only' fits 7-8". Does that mean 215/40 would give better wheel (think curbing) protection and avoid any stretching? If so that'd be another big selling point of it for me.
Old Jan 18, 2008 | 03:55 AM
PGT's Avatar
PGT
the only spec that matters is the manufacturer's. The ones on 1010Tires's calculator are generic....don't read anything into it.
Old Jan 18, 2008 | 07:31 AM
Msteadman's Avatar
Msteadman
Oh okay, makes sense. Just had me a bit confused since they're the same width.
Thanks again
Old Jan 18, 2008 | 07:59 AM
flaco's Avatar
flaco
Mine is lowered with Mach V springs and 7.5 42 offset wheels, 215 45 17 tires. If I'm by myself it's ok, but add more than one passenger or lugggage and there's bad rubbing from all corners on any bump. I'll switch back to JCW springs probably. So it sort of depends on your anticipated load. 215 40 may do the trick too, but I doubt it.
Old Jan 18, 2008 | 08:01 AM
PGT's Avatar
PGT
7.5 ET45 with 235/40/17 clears fine with Mach V springs on an R56. The 215/45/17 is taller than stock...might be the main culprit
Old Jan 18, 2008 | 08:27 AM
Msteadman's Avatar
Msteadman
Hmmm, so maybe I should go for 215/40/17. The wheels I'm looking at are 7.5 ET45 as well. Also considered 235/40, but that size isn't available for the tires I want. I plan on lowering with springs that are even lower than the Mach V's (H&R) plus I frequently have a passenger. Really want to avoid rubbing at all costs.
Old Jan 28, 2008 | 02:37 PM
Wolfgang80's Avatar
Wolfgang80
ET 33?
There is a set of 17x7.5 ET 33 wheels for sale in the classifieds.
Do you guys have an opinion on whether these will stick out past the fender line? Is there more to worry about than them sticking out?
I've looked at OZs in 17x7 ET 37 but haven't seen this wheel in person on a MINI. Are they flush with the fender line?
My calculations show the aforementioned ET33 wheels sticking out an additional .41" versus the OZs.
Thanks for your thoughts.
Old Jan 28, 2008 | 03:03 PM
agranger's Avatar
agranger
I'm runniing 215/40/17 on the stock webspokes and TSW lowering springs (down about 1" all around... maybe 1 1/3 in the back). They fit and drive great. I'm able to run a 5mm spacer on the front to help with clearance on the Wilwoods and still have room to spare.
Now that I've got dedicated track wheels/tires, I'll probably go up to a 45 profile tire next time, though... more meat on the tires to soften the ride a smidge and protect the wheels from potholes.
Old Jan 28, 2008 | 03:06 PM
minipete07's Avatar
minipete07
My 17x7.5" with +45mm offset and 5mm spacers and 215/45-17 tires fit fine on my R56....check my gallery to see side pics of the wheels on....
Old Jan 28, 2008 | 04:04 PM
Wolfgang80's Avatar
Wolfgang80
Thanks MiniPete.
Those pictures help. Now I have to imagine what pushing them out another 1/4" will do.
Old Jan 28, 2008 | 04:28 PM
minipete07's Avatar
minipete07
Thanks MiniPete.
well remember thats a +45offset on a 7.5" wide rim plus 5mm H&R spacers....correct me if i'm wrong but thats a total of +50offset....
Old Jan 28, 2008 | 04:41 PM
Wolfgang80's Avatar
Wolfgang80
Oh boy. I thought spacers push the wheel out, effectively taking your offset from 45 to 40.
I'll have to do some research.
Old Jan 28, 2008 | 04:44 PM
minipete07's Avatar
minipete07
AT least that the guys at M7 told me...might be wrong, let me know what you find out.
Old Jan 28, 2008 | 04:51 PM
Rally@StanceDesign
Actually....it becomes 40mm. The lower the offset, the further OUT the wheel is pushed.
Old May 16, 2022 | 06:52 PM
Pedro Fernandes's Avatar
Pedro Fernandes
A little help pleaseeeeeee
Hy guys, i have one question, do you think JR11 wheels 17 7,5 ET 35 with 205/45 Michelin PS4 Will fit perfect on my mini R56 ? Without any problems?
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Emnotek
Aug 13, 2015 05:47 PM
