R56 jacking points?
Old Jan 9, 2008 | 05:52 PM
maddog's Avatar
maddog
jacking points?
I've searched and searched and can't find any info on where to jack up the car using a floor jack from the front or the back. Anybody know? I'm assuming that once you get the car up, the emergency jack points on the sides are a good place for the jack stands - any other locations?
TIA,
Carl
Old Jan 9, 2008 | 06:05 PM
rattmobbins's Avatar
rattmobbins
I use a 2x4 under the rocker and jacked it up in the middle of the car. Then I put the jack stands under the jacking points in the front and rear.
Old Jan 9, 2008 | 06:17 PM
maddog's Avatar
maddog
Oh OK - I see - so you lift up the drivers side or the passengers side at a time. Convenient for tire swaps front to rear - but I'm still looking for wisdom on front and rear jack points.
Thanks,
Carl
Old Jan 9, 2008 | 06:21 PM
Nightsky's Avatar
Nightsky
There are little square protrusions behind the front tire and in front of the rear tire on the bottom of the rocker panel. Stick a piece of 2X4 between your floor jack and one of those and you'll be fine. Actually, when I raise the front, the rear comes up also.
Old Jan 9, 2008 | 06:27 PM
Minidrivr's Avatar
Minidrivr
Ditto.
Another thread.
https://www.northamericanmotoring.co...d.php?t=119784
Filmy
15
Jun 6, 2023 06:27 AM
asmasm
Aug 18, 2016 09:34 PM
gnhovis
Dec 14, 2015 05:31 PM
Fordgt4
Oct 10, 2015 10:42 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
