R50/53 Next upgrade?
Old Jan 8, 2008 | 08:17 PM
Disco77stu's Avatar
Disco77stu
Next upgrade?
I just bought a used 06 mcs with 20k miles on it, i have the following upgrades and i'm thinking new pipe next? What will get me the most performance for my buck?
  • Webb Motor Sports 15% pulley
  • Alta intake with red silicon hose
  • One-ball exhaust
  • H-sport springs
  • H-sport control arms
  • 17" Rota Subzeros
  • M7 Strut Tower Bar
  • GIAC ECU tune (for 15% pulley, intake)
  • Helix Engine Torque Dampener
Old Jan 9, 2008 | 07:15 AM
greengobln's Avatar
greengobln
15% pulley will get the best numbers for ya. the strut tower brace will get the most stability for ya. after that i'd follow this way
alta intake- whatever color hose you like i like black.
one ball exhaust
giac tune
h sport springs
h sport control
rims and tires
torque dampener
i like to feel the raw power for a little while and then feel it all pulled together with a tight suspension. I haven't done any mods yet but i've been doing a ton of research. i like the alta V2 15% pulley based on a lot of reviews i read.
happy motoring!
Old Jan 9, 2008 | 07:36 AM
HighLife4136's Avatar
HighLife4136
  • One-ball exhaust
  • H-sport springs
  • 17" Rota Subzeros
Rear sway bar.
Old Jan 9, 2008 | 07:46 AM
agranger's Avatar
agranger
IMHO:
1. Brake upgrades - better pads for sure. SS lines and brass bushings for a better feel (both optional).
2. Front camber plates and a good alignment with slightly more negative camber than the stock alignment specs.
3. A quality engine tune (RMW)
Old Jan 9, 2008 | 08:45 AM
slickfast's Avatar
slickfast
Just so everyone knows, the list of upgrades Disco mentioned are upgrades he already has, so no need to suggest them
I would go with the brakes if I was you, as long as your suspension is where you want it. Not much beats a nice set of strong brakes to give you confidence, both on the road and the track!
Good luck, and nice set-up!
Old Jan 9, 2008 | 08:56 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Sway bar is always performance bang for your buck for your suspension.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jan 9, 2008 | 09:11 AM
agranger's Avatar
agranger
Yep... I missed that. The rear swaybar is a relatively inexpensive mod for the change in handling. Any 19mm adjustable rear swaybar should be OK unless you are a hard-core Auto-X junkie. I like having Zerk fittings on the bushing brackets to make re-greasing an easy thing to do.
Old Jan 9, 2008 | 09:31 AM
SpiderX's Avatar
SpiderX
Originally Posted by HighLife4136
Rear sway bar.
+1 no doubt in my mind
Old Jan 9, 2008 | 12:36 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Im going to recommend camber plates and 4 adjustable rear control arms - a quality alignment will do wonders for your handling.
Later, if not sooner, get poly front control arm bushings.
Old Jan 9, 2008 | 12:49 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
I just did the Alta 22mm rear sway bar mod (first mod) and love the way the car feels now. Would highly recommend this.
Old Jan 10, 2008 | 10:33 AM
greengobln's Avatar
greengobln
haha i'm retarded. did not realize these were what he had done already.
+1 for rear sway bar
molala
Oct 2, 2015 01:53 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
