Suspension MC S H-sport rear control arms
Old Jan 5, 2008 | 01:34 PM
Luys's Avatar
Luys
Hi, to everyone
I want to ask about H-sport adjustable rear control arms. Is it give more control to the car only ? and dose it low the car ?
-is it hard to install or adjustable ?
Thanks.
Old Jan 6, 2008 | 10:02 AM
90STX's Avatar
90STX
The rear control arms do not lower (or raise) the car. They allow you to adjust rear camber, which is not adjustable on early cars and only slightly adjustable on later ones. The stiffer mounting bushings and slightly lighter weight improve handling also to degree, but camber adjustability is the big benefit.
Installation is pretty straightforward, but getting to the mounting point nearest the center of the car takes the right combination of wrenches and sockets due to limited access.
Scott
90SM
Old Jan 6, 2008 | 02:06 PM
UKSUV's Avatar
UKSUV
Well...if you want to get uber picky technical. Whenever you go negative camber...the car will squat just a hair lower.
Old Jan 6, 2008 | 06:32 PM
90STX's Avatar
90STX
Hmmm, are you thinking that the inner sidewall of the rear tires will deform more with greater negative camber? Because if it didn't I'd think it would actually raise the car slightly.
I suppose when it gets cold outside the car rides lower too.
Scott
90SM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
