R50/53 Drivers window not making good seal when closed
Old Dec 30, 2007 | 03:18 PM
pimpedout97x's Avatar
pimpedout97x
on my 04 mcs, where the glass meets the rubber seal, right above the door jamb, its not making a good seal. it doesnt leak but i can see the light shine through. whats a good way to line it back up? ill get a pic tomorow in the daylight.
ps- from the outside you cant tell
Old Dec 30, 2007 | 03:25 PM
rwkeating's Avatar
rwkeating
If I am remembering correctly, there is a "reset" procedure in the manual in case the window gets confused and doesn't go up all the way. Maybe that is the problem?
Old Dec 30, 2007 | 03:34 PM
chpsk8's Avatar
chpsk8
He Pimp. Is the window going up and down when you open the door? (it should) If not, as rwkeating suggests, you may need to reset that function. If that doesn't fix it, then the window motor is probably going.
Old Dec 30, 2007 | 03:47 PM
pimpedout97x
no it goes up and down fine, its not an issue of it not going up all the way, its the window is sorta pushed out like maybe 1/4" at most, more like 1/8" though.
Old Dec 30, 2007 | 05:47 PM
chpsk8's Avatar
chpsk8
Well thats not going to be good for your SPL rating now is it? While you're welding in your sunroof you could always build a window channel for the doors. Thats going to be the achilles heel of your system anyhow.
Old Dec 30, 2007 | 09:21 PM
Ancient Mariner's Avatar
Ancient Mariner
There's a procedure in the Bentley manual for reseting the window to seal gap, requiring some serious looking tweaking procedures. Never tried it, but I'm sure someone here can pitch in with some info.
Old Jan 18, 2009 | 09:57 AM
bmwg84's Avatar
bmwg84
His window is not aligned properly. Can someone post pictures on how to realign this glass??
Old Jan 18, 2009 | 10:29 AM
ClubmanS's Avatar
ClubmanS
Look for 2 screws at the very bottom of the metal door.
Dec 23, 2015 10:36 AM
David.R53
Sep 1, 2015 06:49 PM
bugeye1031
Aug 15, 2015 08:14 AM
