Loose Suspension Bolt
Old Dec 30, 2007 | 02:59 PM
BentChainring's Avatar
BentChainring
Does anyone happen to know if the tech's would have any reason to remove the pass. wheel and suspension when R&R'ing a water pump?
I had my water pump replaced about 3k miles ago due to a bad seal. After increasing my tire pressure a bit I noticed a distinctive rattle from the front end. Sounded like a washer clanging on a loose bolt. Today I took the front right wheel off and sure enough, the Strut clamp bolt was loose... not just loose, backed off about 8 threads.
Locktighted and tightened down to ~80ish ft.lbs.
Any thoughts on if I should contact the dealer and complain? Ill call ask mini tomorrow to see if i can file a complaint or anything... If it were a loose hubcap or something, fine... but this i could see being a huge safety issue...
thanks
nK
carid
Dec 28, 2025 04:11 AM
ej
Nov 17, 2015 09:21 PM
mikeson
Sep 6, 2015 06:21 AM
Sep 3, 2015 10:29 AM
Suspension Products
Sep 3, 2015 09:41 AM
