Suspension Sway bar bushings from Energy Suspension?
Old Dec 29, 2007 | 10:34 PM
MINIBee's Avatar
MINIBee
My Alta sway bar is squeeking terribly. I'd like to replace the bushings with something that will stay lubricated. I saw mention of these bushings from Energy Suspension in the Alta forum.
BUSHINGS HERE
They come in a self-lubricating graphite version and with a grease fitting for manual lubrication. Has anyone used these? Results?
Old Dec 30, 2007 | 10:39 AM
brownflyer's Avatar
brownflyer
Hi Mini Bee, is your car lowered? I was having the same issues with my H-sport s/b. Here is my findings and solution (post #9), so far, no more squeaking.
Good Luck
https://www.northamericanmotoring.co...d.php?t=105384
Old Dec 30, 2007 | 08:28 PM
MINIBee's Avatar
MINIBee
Good Luck
Thanks for your reply!
I have stock suspension, not lowered. I found some graphite impregnated bushings that I'm going to try. They're made by Energy Suspension and actually recommended by Alta. So I hope they do the trick!
Old Dec 30, 2007 | 08:39 PM
Jason C's Avatar
Jason C
I'm about to buy the same bushings on Ebay. I have talked to the guy selling them and he said the ones on the site come graphite impregnated (black) with grease fittings. Best of both worlds I guess. Also, a local guy has used these and suggests swapping the straight zerks fittings with 90% ones.
Old Dec 31, 2007 | 12:36 AM
Jason C's Avatar
Jason C
Just realized it's a few dollars cheaper on their regular sit as opposed to their Ebay site.
http://www.energysuspensionparts.com...?prod=9%2E5156
Just FYI
Old Dec 31, 2007 | 10:07 AM
Sin MINI's Avatar
Sin MINI
Good Luck
How much is your car lowered? And can you provide more details on the adjustable end links (where, how much, how hard to install, etc...)? Note I know very little (OK, nothing) about suspension so ...
I have H-sport springs and a 19mm S/b waiting to be installed. If the end links are inexpensive, it may make sense to install them all at the same time.
Old Jan 2, 2008 | 06:19 PM
fishbulb's Avatar
fishbulb
there are two sizes that fit a 19mm bar - one is MUCH bigger than the
other (the one that comes with the grease fitting is the larger one). I bought them from summit, and found out they don't fit. I returned them for the smaller ones which I had a buddy weld some nuts on so I can thread some grease fitting in. About halfway done with that project.
I know that the H&R bushings come set up with a grease fitting, but I could not find that one on the ES website.
rtk90
Aug 29, 2019 09:08 AM
techgearpro
Jul 23, 2019 07:09 PM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
Suspension Products
Sep 2, 2015 10:32 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
