PROMINI Short Shift Kit
Old Jul 10, 2003 | 02:57 PM
Casey's Avatar
Casey
The ProMini quick shift kit reduces shift lever travel by as much as 30%. The shafts are CNC machined 303 stainless steel with 6061-T6 pivot ball, featuring high quality aluminum pivot bushings that replacing the factory rubber units. This is the only way we have found to reduce the sloppy feel of the factory lever. The kits includes CNC 303 stainless steel lever, aircraft quality aluminum lever bushings, billet aluminum shift ****, and full detailed instructions. Lever is designed to accept your original factory shift ****, or any aftermarket universal **** with a 14mm inside diameter.
Fit both Cooper and “S” models.
$139.95
More information at ProMini Short Shift Kit Web Site
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
jziran
Aug 24, 2015 04:50 PM
