Passenger rear floor SOAKING WET
Old Dec 21, 2007 | 07:47 PM
dirkinoff's Avatar
dirkinoff
I was driving my car the other morning after heavy rains "I live in Oregon" and reached behind the right seat for something and the carpet and floor were soaking wet! And no the door was not left ajar, The window was up and the sunroof was closed. Anyone else have this problem yet? I have soaked the car with a hose and cannot duplicate it. I am starting to think it came from the seal under the door and caused by road spray??
Old Dec 21, 2007 | 07:56 PM
dogdal24's Avatar
dogdal24
The same thing happend to my wifes car but both sides of the rear floor where soaking wet(and I mean
PUDDLE! ). Also not able to duplicate it. Thanks for posting I'll be watching this thread.
Old Dec 21, 2007 | 08:59 PM
Msteadman's Avatar
Msteadman
Damn, I can only imagine how much that would suck.
Best of luck to both of you in getting whatever the issue may be resolved.
Old Dec 21, 2007 | 09:41 PM
Gil-galad's Avatar
Gil-galad
Sunroof drain clog??
Seems like I remember a thread on this but can't track it down...
Old Dec 22, 2007 | 09:26 PM
daffodildeb's Avatar
daffodildeb
Windshield replaced?
Old Dec 22, 2007 | 09:29 PM
dogdal24's Avatar
dogdal24
No not on ours. We tried to replicate it but it has only happened once.
Old Dec 22, 2007 | 10:09 PM
-Vampyre-'s Avatar
-Vampyre-
happened on my 07 and it was something with the ac drain seal allowing water to come in their then pool in the back floors
Old Dec 22, 2007 | 10:24 PM
dirkinoff's Avatar
dirkinoff
I have not has the windshield replaced, But I will check to see if I can locate the Sunroof drains, the car was purchased new in june 07 and has been garaged its whole 5000 mile life so I cant imagine it would be pine needles or any leaf debris clogging the drain tubes. They may be mis-installed. Thanks for all the replies and I will keep you posted.
Old Dec 25, 2007 | 08:27 PM
dogdal24's Avatar
dogdal24
Ours was picked up June also. Coincidence?
Old Apr 15, 2008 | 05:27 AM
JMike's Avatar
JMike
Did you ever find the cause of the problem? I just came across the same problem or at least my passenger side rear floorboard carpet was wet and the last rain fall was early last week.
Old Apr 15, 2008 | 06:41 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I was talking with one of the techs at work about this problem, they have been replacing the cavity(door) seals with a new part number that has drains on the bottom part to let the water out.
There is a TSB for this, but your dealer will have to verify that your car has the old style seal(no drains) and that it is in fact leaking water inside the car.
Old Apr 15, 2008 | 03:52 PM
Flyinace2000's Avatar
Flyinace2000
This used to happen to C4 vette's and was a sign that your heater core just died. Replacing it was PITA!
Old Apr 16, 2008 | 05:48 AM
JMike's Avatar
JMike
Thanks for the info. I have my first 1 year maintenance check next month so I will get this checked.
Old Apr 16, 2008 | 07:34 PM
07cooper's Avatar
07cooper
My 07 mcs had up to 1 " of water in the back when raining. I'm told it was the 1st report of it happening. They did everything - new seals, adj doors, sunroof etc. Nothing worked and miniusa took the car back for examination and gave me a new one. It was coming in thru at the rear of the doors between the steel inner shell and the "leatherette" interior finish door panel. I would think there was a sealing problem with the cassette in the door that holds all the window parts.
Old Apr 17, 2008 | 05:26 AM
JMike's Avatar
JMike
Boy, I hope mine isn't that severe. Today we are having a pretty hard rain. I checked the rear after getting to work and nothing is wet yet. I'll see how it is by the time I leave work today. If I have any water in the back I may stop by the dealership on the way home to have it verified by them.
Old Apr 19, 2008 | 08:41 PM
dogdal24's Avatar
dogdal24
We have had a couple of hard rains and it hasn't happened again. First checkup we are going to ask yhe dealer about it.
Old May 3, 2008 | 05:59 PM
dogdal24's Avatar
dogdal24
Just a update: The Wife's car went in and they installed door seal as per bulletin. We are hoping to see no more wet floors!
Old May 4, 2008 | 07:49 AM
JMike's Avatar
JMike
Thanks, I need to make the first checkup on mine this month. So I'm going to bring it up to the dealer also. I was hoping I would get one more wet floor so I could actually take it in and show them, but hopefully I'll get the seal replaced and will not have the problem again also.
Old May 4, 2008 | 08:32 AM
r56mini's Avatar
r56mini
Do you all have a sunroof? The old bimmer I sold had the same problem. The sunroof drain holes were all functional but the carpet was soaking wet after a hard rain.
Old May 5, 2008 | 05:20 AM
JMike's Avatar
JMike
I do have the sunroof on mine. That is what I first thought of also but since both front seats are all the way back, I couldn't see how anything would drip onto the rear floor board without getting the seats wet instead.
Old May 5, 2008 | 11:35 AM
ruabadfish2's Avatar
ruabadfish2
Mine had the same problem. MoSA replaced the weatherstrips on the passenger and driver side door, just to be sure. Have not had a leak since.
Old Dec 15, 2008 | 08:34 PM
JCW2009's Avatar
JCW2009
FYI: I took my Mini in today because it had a leak in what seemed to be from the boot window. It turns out that the drain tube of the back seat sunroof was not connected. The water was traveling backwards on the liner, and would come out where the center brake light is, on top of the back window.
Maybe in your case the water travels to one side, and that is how you get your rear floor wet? Try running the hose on top of the sunroofs, and see if that will duplicate the problem. Good luck.
Old Mar 21, 2012 | 02:13 PM
conrad0102's Avatar
conrad0102
Hi guys, My 2007 MCS has the dual sunroof and I went home for spring break and found my floors soaking wet. It had rained heavily the night before so I naturally thought it was my sunroof or sunroof drains. I had my mechanic take a look at it. He ripped out all the carpet and padding to try and save it from mold and mildew. He had a friend of his soak the car from the outside with a water hose while he sat inside and looked for a leak. It eventually got too hot for him and he turned on the A/C and Turns out it was the A/C drain leaking. I had a lot of water in my back floors. I get my cooper back this weekend. Hopefully some of this information helps someone out there!
Old Mar 21, 2012 | 02:29 PM
mdsbrain's Avatar
mdsbrain
So weird this is like a old problem the Gen 1 cars would have. Except on Gen 1 cars it would happen in the driver seat floor area.
Old Mar 21, 2012 | 02:50 PM
conrad0102's Avatar
conrad0102
I'm not sure why it was my backseat but mine was in my driveway tilted up so I'm sure that had something to do with it but as to why it was mostly on the driver side I have no idea...
