Team Dynamic VS OZ Ultraleggera
Old Dec 21, 2007 | 12:16 PM
slvgmini's Avatar
slvgmini
Hi, I am trying to decide on whether to buy Team Dynamic 18" Flat black wheels, or OZ Ultraleggera 18" Black wheels. I am asking for help, if anyone could give me the good and the bad of each wheels, it would be much appreciated.
Old Dec 21, 2007 | 12:45 PM
glnr13's Avatar
glnr13
wheel weights arent a matter at that size. i think theyre comparable in weight for the TD Pro Race 1.2 vs the OZ u-leggeras
both companies are used by race teams all over the world. both well made wheels.
i'd choose based on availability and price. same difference really
also noticed you have an 07. do you have the new TPMS? that'd be deciding factor also, make sure they can fit the new TPMS
Old Dec 21, 2007 | 01:03 PM
tazio's Avatar
tazio
Could be wrong, but I don't think either of these are forged, though they are reasonably light I think there is a pricier "Forgiata" version of the OZ to be had. IMO the TD wheels are more business-like in appearance to the OZ ULs, which are a bit over-styled and too angular in design for the MINI. The OZ SL was a good MINI wheel, though. I had a set back in the day and now have TDs. Again, just one idiot's opinion.
Old Dec 21, 2007 | 01:05 PM
glnr13's Avatar
glnr13
you're right taz... my bad, i mustve been trippin. edited
Old Dec 21, 2007 | 01:09 PM
07chilired
I have the TD pro race 1 wheels in flat black and I love them
Old Dec 21, 2007 | 02:01 PM
jonnieoh's Avatar
jonnieoh
I have the TD pro race 1's as well, in the 17-inch size, black. I too, love them!
I did look at the OZ's, but I thought the spokes looks a bit beefier/more substantial on the Team Dynamics wheels. They looked stronger. I had seen them on MSFITOY's MINI, and really liked how they looked.
The spokes on the OZ's look thinner; more knife-edged, and I didn't like how they merged with the outside of the rim. That area gets awfully busy, and looks like it creates lots of little places for brake dust to collect!
Zoom into a photo of the Ultraleggera's, and you'll see what I mean...
I don't know about you, but how easy a wheel is to clean is a pretty big factor for me... A wheel with excessive amounts of nooks and crannies means MORE LABOR when you detail your wheels...
Old Dec 21, 2007 | 02:28 PM
TrboKrt's Avatar
TrboKrt
I have not seen any more time wasted dealing with my OZ UL's from the Web Spokes I had before, maybe less time each wheel to wash and dry. They sure do hide brake dust nicely between washings.
The OZ rims are quite nice in how they handle other than being a little too loose on takeoff (have to readjust to how lite they are). All in all very good rims IMO.
Old Dec 21, 2007 | 02:35 PM
slvgmini's Avatar
slvgmini
I do have the new TPMS, are the Team Dynamics able to hold the TPMS unit? I think the OZs are able to.
Old Dec 21, 2007 | 02:55 PM
07chilired
mine do...every time I rotate them or take them off the TPMS light comes on
Old Dec 21, 2007 | 05:00 PM
Msteadman's Avatar
Msteadman
Interesting, I read somewhere else here on NAM that only the TD Pro Race 1.2's are able to accommodate the larger valve stem of the TPMS system. Sure your MINI doesn't have the older FTM system?
I really like the OZ Ultraleggera's as well; their weight is unbeatable for the price. However, since I won't be tracking my MINI at all, the design of the TD's won me over. I prefer the gloss black and machined lip they have, over the UL's flat black. Also the TD's are supposed to be tougher and cost significantly less than the UL's.
Really you can't go wrong. Both are beautifully designed, light, quality wheels.
Old Dec 21, 2007 | 05:07 PM
glnr13's Avatar
glnr13
based on the post date of some of your pics 07CR i dont think you have the new TPMS...
does your valve stem look like this?
if not you have the older TPMS... much easier to deal with than the new one
Old Dec 21, 2007 | 05:13 PM
Msteadman's Avatar
Msteadman
Same thing I was thinking. The new system only showed up around build week 32 or so. Personally I'm starting to think the older system definitely has its advantages. Even with the direct system we don't get actual PSI readouts and you can only see which tire is low if you have the OEM navigation system. Has any research/experimentation shown that the new system even detects a flat any sooner???
Sorry just had to rant a little bit. My MINI has the new TPMS system and I'm looking to put on aftermarket wheels/tires soon. So it's either gonna be a major pain in my a*s (switching the parts over) or in my wallet ($183 for new sensors and stems from Tire Rack).
Old Dec 21, 2007 | 05:35 PM
FugitiveAI's Avatar
FugitiveAI
I haven't heard of anyone getting wheels the TPMS sensors didn't fit in. Not to say this isn't a valid concern that has been a problem for some, but it doesn't seem to be the most common problem. The issue myself and everyone else I've chatted with has run into is that many wheels have 12mm lug holes and the new MINI R56 has 14mm lugs.
Old Dec 21, 2007 | 08:38 PM
ezpeasy's Avatar
ezpeasy
Msteadman,
As you know I went w/ the OZ's and I bought the sensors through TireRack. The interesting thing is one of the wheels came inflated to 85psi.
When I first found this I assumed my guage wasn't getting the right reading because the tire sensor would surely call this out. But the car had a wicked pull so I suspected something was up and checked w/ another guage that also read high. When I let the air down to 40PSI where it should be, the system told me I had a low tire?????
This really freaked me out since the tire looked fine but I didn't want to drive w/ a flat. What I realized is that the TPMS when you set it assumes the set pressure is correct and only alerts you when there is a drop by a certain percentage from that point. So if you reset at 90psi and drop to 60psi, they will all go off.
Clearly for such a complicated system, it sure is dumb!:impatient Another government mandate at work!
Old Dec 21, 2007 | 08:42 PM
tazio's Avatar
tazio
This new TPMS thing sounds like a huge PITA.
Old Dec 21, 2007 | 09:08 PM
Msteadman's Avatar
Msteadman
Originally Posted by ezpeasy
Msteadman,
That is insane, 85psi!?! WOW.
Totally forgot about the government mandate. That has to be the only reason MINI switches system. At first I thought it was cool but it seems we get no added features over the FTM system, it's no more 'sensitive' or what have you and it's a major pain to deal with when it comes time to switch wheels.
My thoughts exactly. It doesn't just sound like it, for me at least, it is. I could totally live with the hassle if it was any better of a system. But thus far it just doesn't seem to offer any improvements at all. Granted it's newer and arguably better technology, but I've yet to see how that transfers over to making it better.
Old Dec 21, 2007 | 09:12 PM
PGT's Avatar
PGT
the ultraleggera has a very angular look to it...not flowing and smooth like the TD's. I love the look of a flowing balanced 10 spoke wheel....timeless in design vs. the spoke pairs of the OZ. Prodrive P1 (made by OZ), Prodrive GC010's, Rays Optimise 57 (nine spoke but who's counting), etc.
Old Dec 22, 2007 | 01:23 PM
a96bimmerm3's Avatar
a96bimmerm3
Gabes car from motoringfile looks AWESOME on superleggeras. My vote is for the OZs, I almost got them but decided for 16s instead when tirerack was out of the black ones.
ymmv,
Josh
Old Dec 22, 2007 | 02:49 PM
MiniMac2005's Avatar
MiniMac2005
ymmv,
Josh
yup they looked good on his R53, they still look good on his R56. Another MINI guy he runs with has them on his JB/B as well.
Old Dec 22, 2007 | 03:10 PM
PGT's Avatar
PGT
superleggera = discontinued
Old Dec 22, 2007 | 03:45 PM
tazio's Avatar
tazio
Gabe's car = Ultaleggeras
Old Dec 22, 2007 | 03:54 PM
PGT's Avatar
PGT
ok, terrific
Old Dec 22, 2007 | 05:16 PM
MiniMac2005
you are correct... went back to look at a pic when he bent his rim...it is an Ultraleggera, not Superleggera. Sorry for the confusion...
Old Dec 22, 2007 | 08:58 PM
tazio's Avatar
tazio
I'll let it slide this time. But PGT is going to kick yo a$$ back to the Stone Age.
Old Dec 22, 2007 | 09:00 PM
PGT's Avatar
PGT
sho nuff
