brake pad question
Old Dec 5, 2007 | 06:56 AM
bcorn's Avatar
bcorn
brake pad question
Are mintex brake pads the same as oem.
I have always run the oem brake pads on my mini and have been very happy with them. I autocross and have always been told by other autocrossers with minis that oem are as good as anything else. I threw on some $20 O'reilly pads to keep from gouging the rotors and OH MY GOD DO THEY SUCK! ! ! !
My mini deserves more.
In need of an economical solution... $90 pads are not an option. I am also replacing both outer cv joints (am I the only one who has killed cv joints on a mini?) and the front lower control arm bushings (second time). Mini won't honor the waranty because I have koni yellows.
bcorn
Old Dec 5, 2007 | 07:28 AM
txwerks's Avatar
txwerks
Mintex RedBox pads are fine for the street and autocross, IMHO. As far as I can tell, they're not quite the same as OEM.
Have you thought about a different option for the CA bushings? Are you talking about the 'lollipop' bushings at the rear of the control arms? If so, the Powerflex are a much better solution than the OEM rubber - or, the Alta PSRS if you want something even beefier.
Old Dec 5, 2007 | 07:37 AM
bcorn's Avatar
bcorn
Yes.
Powerflex... I see vendor under your name. Could I get them from you?
bcorn
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
penguinhomey
Aug 17, 2015 01:33 PM
