R56 Pumping Gas Question
Old Nov 19, 2007 | 07:42 PM
RVExotics's Avatar
RVExotics
I've only had my Mini for a few days, and have put gas in it twice. Both times, I've had the gas pump do it's auto-shutoff way before the tank was full. I've noticed the entrance into the gas well is rather slim, so is it the pressure pushing back against the pump that is causing it to shut off early? My real fear here is: if I keep forcing the pump to come back on, I may accidentally hit the point where gas comes shooting out from around the pump handle. Obviously, this I want to avoid!
Is this premature shutoff issue something everyone faces? What do you do about it? I suppose I could just give it a rough estimate based on how many gallons appear to be left in the 14-gal tank...but that's rather inaccurate. Something a bit more precise and efficient would be appreciated! Thanks in advance for any advice.
Old Nov 19, 2007 | 07:53 PM
Msteadman's Avatar
Msteadman
I recognized this as well in pumping up my MINI the first few times. What I do is let the pump go full blast until the first 'auto-shutoff'. Then I slowly let it pump a second time until it shuts itself off again. I've never had any problems with gas shooting out using this method nor an only partially full tank. My main suggestion is to not pull the gas pump out at all in an attempt to get more gas in. It's tempting and I haven't tried this yet on the MINI, but I've seen other people do it to only result in gas running down their cars paint.
Happy Motoring!!! Your MINI is gorgeous.
Old Nov 19, 2007 | 07:59 PM
irieman's Avatar
irieman
I learned how a gas pump works in my Physics class (C+ baby!). As gas rises in the tank the degree of suction changes accordingly. Without any data to back it up, I have always assumed that more modern pumps are designed to be even more sensitive than described in the link above, thereby suffering from Premature Shutoff.
I have yet to spill gas out of the tank of a MINI, as, at one point, it's pretty obvious the tank is full (the handle clicks off instantly).
I'm sure a more learned individual will ad further insight. At least I hope so!
Last edited by irieman; Nov 19, 2007 at 08:14 PM. Reason: changed link to better resource
Bhatch's Avatar
Bhatch
Turn the nozzle slightly clockwise, about 15 to 30 degrees.
There are some here where i live that will not even poor gas into the car unless i do this.
Old Nov 19, 2007 | 08:09 PM
acebutt's Avatar
acebutt
Set the handle on the first notch. Slower pumping = less back pressure which shuts off pump.
Old Nov 25, 2007 | 06:25 PM
checkercoop's Avatar
checkercoop
the best thing (which i did with my previous car) is to put the pump about 2/3 of the way in...the best things is try and allow a gap between the pump nozzle and the opening that way the pressure can escape with the premature shut off...it always stops at the correct time if you do it this way....ive never had gas shoot out my car doing it this way
Old Nov 25, 2007 | 09:05 PM
Minidrivr's Avatar
Minidrivr
No problems here with mine. I let the pump shot off and the gauge indicates full.
Steffen.Johnson
Aug 23, 2015 08:30 PM
dchang0
Aug 10, 2015 03:37 PM
bc219
Aug 10, 2015 11:22 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
