Drivetrain m7 oil cc
Old Nov 9, 2007 | 10:04 PM
herbie hind's Avatar
herbie hind
m7 oil cc
i know this has been discussed here before but; has anyone had an issue with the routing of the lines as per m7's instrutions / thx .
Old Nov 10, 2007 | 06:08 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Yes. Although I never experienced the collapsing tube problem some have had with Alta tubing, I picked up a lot of water vapor and little oil when routed the way M7 says in the instructions. There was still oil in the IC, too. When routed the preferred way (as per my sketch, see elsewhere or my website) I got oil in the can, and an absolutely clean IC (surprisingly oil-free.)
Old Nov 12, 2007 | 07:31 AM
Bahamabart's Avatar
Bahamabart
I did their set-up originally and had smililar results like Phil. I also had the collapse problem but I had used non-M7 tubing.
I ended up going to the single side (left) and its working effectively. I also added a metal filter (screen) to the inside of the M7 can and that helps alot.
Old Nov 12, 2007 | 05:35 PM
MiniStupidfun's Avatar
MiniStupidfun
i dont have in mounted the way that m7 suggests, nevetr had an issue with that
Old Nov 16, 2007 | 10:48 PM
herbie hind
thx for the replies all . i went single side and put it where my c.a.i. used to be . lots of room .
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
