Suspension Hartge spring + ultraleggera (offset 37mm) + 205/45/r17 = rubbing ?
Old Nov 8, 2007 | 06:21 PM
vodka's Avatar
vodka
Hi All,
My 04 MINI ONE CVT current setup is :
- stock suspension/spring
- 17" oz ultraleggera offset 37mm
- 205/45/r17 michelin pp2 tires
Currently the ride is no rubbing and I'm thinking of changing the spring to Hartge lowering sport spring, what do you guys think? Will it rub? Will it over kill my ONE?
Thanks alot
Old Nov 8, 2007 | 08:38 PM
minimusprime's Avatar
minimusprime
i have those wheels with those size tires. You are g2g on any springs. If you do get any rubbing it will be very very slight and will only rub a couple of times and will go away. Definitely no harm done. 215/45's you may experience some rubbing. You can always add some camber and it would go away.
Old Nov 9, 2007 | 01:58 AM
Coen_de_K's Avatar
Coen_de_K
mine is 7j 18" wheels with 215 tyres and lowerd 6cm's
offset is 38
no rubbing here
Coen
freeman727
Dec 10, 2017 04:00 AM
gar56
Nov 15, 2016 06:41 AM
sssevita
Mar 20, 2016 06:24 AM
rt808
Sep 29, 2015 03:15 PM
gnhovis
Sep 28, 2015 10:56 AM
