Stock Driving Lights
Old Oct 20, 2007 | 08:16 AM
yellowbritishrocket's Avatar
yellowbritishrocket
I have a 03 MCS with the OEM driving lights....they worked just fine.....until recently...went to turn them on and nothing....have no idea what is going on....any help?
Old Oct 20, 2007 | 08:41 AM
early_apex
The driving light install instructions are here. Check all the connections. I'd pop the switch out and make sure the harness is plugged in properly there. http://www.outmotoring.com/images/ho...Lights_902.pdf
Old Oct 20, 2007 | 08:42 AM
early_apex
Also, I don't think they work with the brights. Make sure your bright lights are off.
Old Oct 20, 2007 | 09:07 AM
yellowbritishrocket
no these only come on when the brights are on
Old Oct 20, 2007 | 02:59 PM
early_apex
Ok, right, I knew it was something like that. I'd check all the connections and the fuse if there is one.
Old Oct 20, 2007 | 09:37 PM
Eric_Rowland's Avatar
Eric_Rowland
Does the switch still light up?
Check the fuse in the engine compartment, as well as the ground.
It will be easier if you can confirm that you have power from the fusebox, then just follow the harness. Do you have an multi-meter?
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
