Navigation & Audio seat removal and battery disconnect
Old Oct 14, 2007 | 09:08 AM
kookmyers's Avatar
kookmyers
Hi all. Easy questions for ya.
1. How do i remove the seats without getting the airbag code?
2. If i disconnect the batttery, will that trigger some sort of code?
Old Oct 14, 2007 | 09:52 AM
PGT's Avatar
PGT
1. unplug the battery, disconnect harnesses, unbolt
2. maybe...50/50 shot
Old Oct 14, 2007 | 09:56 AM
DyeLooper's Avatar
DyeLooper
I unbolted the seat and used a big unused roll of paper towels to hold the seat up to do what I needed to do.
Old Oct 14, 2007 | 10:27 AM
tazio's Avatar
tazio
So long as you disconnect and reconnect the airbag harness while the battery is off line, you will be fine. I did this and swapped in a 4ohm resistor with no problems at all. If you bring the power up with the airbag disconnected, you will throw a code and trigger the warning light, but this can be reset by any decent mechanic once everything is hooked up properly.
Old Oct 14, 2007 | 10:43 AM
djam43's Avatar
djam43
You will not have any problem with code/alarm if you disconnect the battery first.
Old Oct 14, 2007 | 11:06 AM
Coffeeman's Avatar
Coffeeman
You might want to disconnect both positive & negative terminals, then touch both positive & Negative cables together, to bleed off any residual voltage in the system...OR disconnect the battery, and wait 30 minutes before removing the seat.
Getrieben
Sep 12, 2024 07:03 AM
flyers47
Jul 27, 2020 02:38 PM
eatsleepautox
Oct 30, 2015 06:46 AM
Mini'mon
Aug 26, 2015 01:02 PM
DWooderson
Aug 10, 2015 09:12 AM
