AMSOIL 5W30 Synthetic Data Sheet
Old Jun 24, 2003 | 11:24 AM
Zappa's Avatar
Zappa
Use this to compare with your current oil selection. Follow the service guidelines below and save money. Trust 30 years of synthetic technology founded by Al Amatuzio.
SAE 5W-30 SYNTHETIC MOTOR OIL
Recommended for Applications Requiring the Following Specifications:
API SL, SH, SJ, CF
ILSAC GF-1, GF-2, GF-3
Chrysler MS 6395 H
Ford WSS M2C-153G
GM 4718-M
VW 500.00, 501.01, and 505.00
Energy Conserving II
Mercedes-Benz AG 226.1
All AMSOIL Synthetic Motor Oils dramatically outperform conventional petroleum motor oils. They reduce friction, heat and wear for maximum power, performance and fuel efficiency. Resistant to high temperature burn-off, chemical breakdown and sludging -- keeps engines cleaner. Provide low temperature fluidity for fast, dependable winter starts and immediate start-up protection. Exceed the most demanding world-wide performance standards and meet warranty requirements for all domestic and imported passenger car engines, both turbo-charged and non-turbo-charged. Up to 25,000-mile or 1-year drain intervals. Product Code: ASL
PRODUCT DESCRIPTION
AMSOIL 100% Synthetic 5W-30 Motor Oil exceeds the lubrication requirements of all modern automobile engines, providing tough lubricating protection in the most demanding operating conditions. It resists high temperature degradation and flows freely in cold conditions for substantial reduction in engine wear. AMSOIL 5W-30 provides excellent engine protection, maximum power, improved fuel efficiency and extended oil drain intervals.
Resists High Temperature Vaporization
AMSOIL Synthetic 5W-30 Motor Oil resists vaporizing in the high temperatures that vaporize petroleum motor oils. High vaporization loss leaves a thicker, higher viscosity oil than is recommended. The NOACK Volatility Test, which measures the weight loss of an oil due to evaporation, shows that most 5W-30 petroleum motor oils fail to pass the 13 percent ACEA pass/fail limit. In fact some oils lose as much as 25 percent of their weight to volatility. AMSOIL 5W-30 Motor Oil loses only 6.9 percent of its weight. AMSOIL 5W-30 remains a 5W-30. It provides consistent high temperature protection and reduces oil consumption and harmful emissions.
Resists Oxidation and Thermal Breakdown
AMSOIL Synthetic 5W-30 Motor Oil resists the damaging effects of heat, blowby chemicals and oxidation up to 10 times longer than petroleum motor oils. AMSOIL 5W-30 resists forming varnish deposits and sludge. It doesn't thicken like petroleum oils, but continues to cool and lubricate, providing peak engine performance and extended drain intervals. In addition, the advanced heat transfer capabilities and high lubricity of AMSOIL 5W-30 reduce excessive operating temperatures of engines, transmissions and gear boxes, so they run cooler, cleaner and longer.
Provides High Shear Stability
AMSOIL 5W-30 surpasses the North American SAE and European ACEA oil specifications for high temperature/high shear (HTHS) viscosity. It doesn't shear back to a lower viscosity oil in the high temperature/high shear conditions of today's smaller, high RPM automobile engines. AMSOIL 5W-30 maintains an extremely protective viscosity of 3.5 cP at 302╟F (150╟C) in the ASTM D-4683 High Temperature/High Shear Test, far exceeding test limits of 2.9 cP.
Provides Low Temperature Protection
AMSOIL 5W-30 remains fluid at temperatures as frigid as -60╟F (-51╟C). It permits easy engine cranking for fast starts and in sub-zero temperatures flows to all engine parts much faster than petroleum motor oils. The exceptional cold temperature properties of AMSOIL 5W-30 provide immediate cold start lubrication, greatly reducing engine wear and prolonging engine life.
Resists Deposit Formation
Because AMSOIL 5W-30's synthetic formulation resists oxidation so well, it runs naturally cleaner than petroleum motor oils. AMSOIL 5W-30 also contains special detergent/dispersant additives that, when tested after tens of thousands of miles of use in the crankcase, still exhibit outstanding deposit control. This combination of natural detergency and advanced additive package keeps AMSOIL 5W-30 effective for up to 25,000 miles or one year in non-turbocharged gasoline-fueled cars.
Prevents Rust and Corrosion
AMSOIL Synthetic 5W-30 contains special rust and corrosion inhibitors to protect iron parts, as well as copper, lead and aluminum bearing materials.
API SL, SH, SJ CF
Ford M2C153-G
GM-4718M, 9986137
DB 229.3, 229.1
VW 502.00/505.00
MIXING AMSOIL
AMSOIL 100% Synthetic 5W-30 Motor Oil is compatible with conventional petroleum oils; however, mixing AMSOIL 5W-30 with a conventional oil will shorten the drain period of AMSOIL 5W-30. Engine oil additives or after-market products are not recommended for use with AMSOIL 5W-30.
SERVICE LIFE
In personal cars and light-duty trucks with non-turbocharged gasoline engines: drain oil at 25,000 miles or one-year intervals, whichever comes first.
In turbocharged gasoline engines, motorcycles, ATVs, marine craft and occasionally used gasoline engines: drain oil at intervals up to three times as long as the intervals recommended by the engine manufacturer or one year, whichever comes first.
In high performance and racing engines: drain oil according to the findings of used oil analysis.
In light-duty and non-turbocharged diesel engines: drain oil at intervals up to twice as long as those recommended by the engine manufacturer or one year, whichever comes first.
In fleet and industrial engines: drain oil at intervals up to three times as long as those recommended by the engine manufacturer if the findings of a used oil analysis program support the extended drain intervals.
If the vehicle is equipped with an AMSOIL Oil Filter, the filter should be changed at 12,500-mile or six-month intervals (whichever comes first) in gasoline engines and 7,000-mile or six-month intervals (whichever comes first) in diesel engines. Non-AMSOIL oil filters should be changed at the engine manufacturer's recommended filter change intervals.
AMSOIL synthetic motor oils are fully compatible with conventional motor oil. For best results, however, use AMSOIL Engine Flush, then install AMSOIL synthetic motor oil.
For maximum engine protection, use an AMSOIL Oil Filter and an AMSOIL Air Filter.
Note: Most quick lube service centers will install these products upon request or install them yourself.
TYPICAL TECHNICAL PROPERTIES
AMSOIL 100% Synthetic 5W-30 Motor Oil (ASL)
Kinematic Viscosity @ 100╟C, cSt (ASTM D-445)
11.7
Kinematic Viscosity @ 40╟C, cSt (ASTM D-445)
63.4
Viscosity Index (ASTM D-2270)
182
CCS Viscosity @ -25╟C, cP (ASTM D 2602)
2555
Borderline Pumping Temperature ╟C (╟F) (ASTM D-3829) <-40 (-40)
Pour Point ╟C (╟F) (ASTM D 97)
-51 (-60)
Flash Point ╟C (╟F) (ASTM D 92)
230 (446)
Four Ball Wear Test (ASTM D-4172 B: 40 kg, 75╟C, 1200 rpm, 1 hour, Scar in mm)
0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 6.9
High Temperature/High Shear Viscosity cP, 150╟C, 1.0 X 106 s.-1, (ASTM D 4683),
Minimum 3.5
Total Base Number
>11.0
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
nashvillemini
Sep 30, 2015 10:26 PM
EVMini
Sep 28, 2015 10:20 AM
