R56 Redline oil
Old Sep 22, 2007 | 04:08 PM
1825vine's Avatar
1825vine
Redline oil
What do you think about these expensive Redline motor oil? Are they any good? Thank you.
Old Sep 22, 2007 | 04:36 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Redline oil is good.
Worth the extra cost? Only you can decide but many that track their MINIs will use Redline and change oil at least twice as often as other owners do.
Maybe every 3000 miles.
For street used MINIs, you can also choose less costly oils and they will also do OK.
Some other common oils-
Castrol Full Synthetic (as recommended in your manual)
Amsoil
Mobil 1
Royal Purple
Old Sep 22, 2007 | 05:00 PM
Robin Casady's Avatar
Robin Casady
Supposedly, the USA version is different than the European version spec'd by MINI. USA 5-30 is said to be thinner than Euro. 5-30. Safest, to get the MINI branded version from the dealer. Price is reasonable.
Amsoil
Mobil 1
Royal Purple
I have no experience with Amsoil or Royal Purple. For Mobil 1, be sure to get Mobil 1 Extended rather than just Mobil 1 -- unless you plan to change the oil every 3000-5000 miles. However, the MINI branded Castrol is less expensive, and rated for 15,000 miles.
Old Sep 22, 2007 | 08:23 PM
Bhatch's Avatar
Bhatch
you forgot MOTUL , but i'm a track *****.
I love it, high flash point and they have good brake fluid too :P
Old Sep 23, 2007 | 02:12 AM
smackboy1's Avatar
smackboy1
My $0.02 is that if you're going to try out different more exotic brands of oil or change the oil change interval, it would be worth it to get used oil analyses to actually verify if there is any improvement or degradation in performace.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
