M7 R56 AGS-R and some other goodies.
Old Sep 17, 2007 | 11:12 PM
M7's Avatar
M7
Finally cast in stone and ready for prime time, the R56 AGS-R is going into production shortly with delivery scheduled in October.
The AGS-R is the best performing R56 Cold Air Intake system currently
on the market. We have added tons of features to keep this system the best performing and best looking available....
Here are some exclusive features not available from the competition:
1. Composite construction minimizing heat soak of the intake box.
2. A properly designed intake tract allowing the air to speed up with
no restrictive air-box interface. We also added vortex generators to
minimize restrictive laminar flow. The filter will see the airflow across
the whole 12" of filter media, not just a small portion of it.
3. A huge 12" dual stage foam filter with a 3" tube interface that will outflow any flow requirement the engine will ever need. The MAF interface is 3"OD.
4. As we designed and tested this system, it become very clear that it was almost as quiet as the stock system. This is a bummer because the sound
from the blow-off valve can be pretty addictive.. So I started to think
what if we could tune it to any noise level--quiet for the commuter who
needs to be on the phone, a little noisier for some more spice, and
outrageously noisy for guys like me....Enter the
"Knock-out sound ports" ingenuously simple for total sound control and added value for you the consumer. (See Image)
5. We realize that some people are concerned that water will be ingested in copious amounts if there's a down pour or Tsunami...
After looking really close at the dynamics of pressure inside the box and
possible pooling of water in a rain storm or worse, we decided to add
rain/water valves in the lowest area of the intake box. As water enters the
the intake box some will atomize and enter the engine (no harm) and cool the intake charge (good thing), while larger droplets will accumulate towards the lowest area in the box and thus exit through the water valves due to the high box pressure.
6. We also kept servicing the engine in mind. Oil can be changed without removing the AGS-R. For sparkplug service, just remove the AGS-R (two M6 button head screws) and losen the rubber downtube. This will take all of 3 minutes....simple.
7. Since the AGS-R is not attached to the hood, a Strut Tower Brace will comfortably fit right above the air box with no issues.
8. Depending on the finish you add to the AGS-R, people will think that the unit is a factory equipped part, not aftermarket.
9. The R56 Ram Scoop and soon to be revealed the R56 Extreme Scoop
will be a fabulous addition to this system, and at the same time add
a little extra style to your hood.
10. Heat is enemy numero uno under the hood of the R56. So the AGS-R
will have a simple but very effective heatshield. But as everyone knows
here on NAM..... M7 will not stop with simple. So we will have something
super cool and this design is exactly what the R56 connoisseur is looking for . . . Aerogel/Ceramics....... the full secret will be out next week.
11. Lastly, a couple of thoughts on the importance of cool air to the engine.
As we tested the AGS-R through these months, we found that the changes from a simple K&N filter to the AGS-R made a profound difference in how the car reacted to throttle inputs at low or high speeds. At highway speeds
goose bump inducing warp speed was only a jab away on the loud pedal
and that was in sixth gear.....Wow. If you needed something a little bit
more girlfriend (or boyfriend, spouse) scream inducing....
fifth gear will now make things a little bit more frantic and by the way.... that's at 90mph. (These speeds are aided by the fantastic Unichip
R56 module soon to be released).
The AGS-R price will be $629 for black gel coat with some options like color matching to your R56 for an additional $225, or a sporty CF layer on the top cover will add $100.
We will also have a solid CF version available at a premium, as this version is vacuum bagged for a flawless finish, is extremely light weight and priced at $1250.
Feel free to call me any time if you have any additional questions I might not have touched on.
peter
M7 Tuning
562-608-8123
AGS-R in optional Black Finish
AGS-R with
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 4, 2015 01:32 PM
