17x7 RIMS offset 37mm, what tires size will you choose?
Hi All,
Want to change to 17x7 RIMS offset 37mm for my 04 MINI ONE CVT which run on stock suspension/spring, etc. If you were me, what tires size (below) will you choose without any rubbing/etc issues?
1. 215/45/R17
2. 215/40/R17
3. 205/40/R17
4. 205/50/R17
Sorry, goodyear F1 dont have 205/45/R17 size
Please help me choose, or anyone running any of above size with 37mm offset facing any problem?
1. 215/45/R17
2. 215/40/R17
3. 205/40/R17
4. 205/50/R17
Hi All,
1. 215/45/R17
2. 215/40/R17
3. 205/40/R17
4. 205/50/R17
1. 215/45/R17
2. 215/40/R17
3. 205/40/R17
4. 205/50/R17
215/40-17 will work but is smaller tire diameter so harsher ride and more wheel gap, same with 205/40-17 plus low load rating- make sure it is at least 84.
205/50-17 is taller than stock so not the best choice of these.
If you choose a tire that is 205/45-17 then that would also work well, there are some but the selection is limited.
In this stock size there is a Goodyear F1 (All season) it's new.
$122 each 420 treadwear. Very good balance of comfort and good handling wet or dry at reasonable price. Very good street tire, will outlast the Goodyear Eagle F1 GS-D3.
see
http://www.tirerack.com/tires/tires....+F1+All+Season
DrFraserCrane
Aug 30, 2015 01:11 PM
