New tires advice----please
Old Jul 25, 2007 | 06:34 AM
gary442's Avatar
gary442
Have 2007 17" Crown Spokes with 205 45 17 mounted on my 2003 MCS with stock suspension and brakes. Want to go to non-runflats for a better ride and understand that 215 45 17 will also fit without clearance problems ...is this so ? thanks
Old Jul 25, 2007 | 08:06 AM
jakay11's Avatar
jakay11
going up from 205 to 215 will increase your rolling diameter from 24.26 to 24.62, which is ~1.5% larger, which *should* be OK, but keep in mind that your speedo and odo will read that 1.5% too low (IE, you will be going faster than your speedo says)
Old Jul 25, 2007 | 09:04 AM
kenchan's Avatar
kenchan
yah, but that speedo difference is like within the tire pressure tolerance.
from a dressup perspective, those new R56's need a thicker tire to withstand
the boldness of those huge fender arches, unless you paint them. looks
unbalanced.
Old Jul 25, 2007 | 10:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Yes, you are fine, the 215/45-17 is taller than stock and wider but it's close enough.
If you do lower your MINI then you can start to get a little rubbing in the rear outer edges.
Which tires are you going with?
Old Jul 26, 2007 | 06:06 AM
gary442's Avatar
gary442
Thanks for the advice...went with Kuhmo AST 215 45 17..am very pleased as the ride is much improved and the car looks "beefy".....
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
