R50/53 Bog from stop w/ AC
Old Jul 18, 2007 | 07:49 PM
Tomcatta's Avatar
Tomcatta
Bog from stop w/ AC
I'm new to the whole Mini scene. I have a 2005 MCS w/ stick. Awesome little car, but it seems to bog down slightly when leaving from a stop with the A/C on. With A/C off, seems fine. Is normal behavior of a Mini, something inherent with a small displacement engine being taxed by the A/C, or a possible service issue?
Old Jul 18, 2007 | 07:50 PM
Dr Obnxs's Avatar
Dr Obnxs
Sorry....
Small motors and big loads don't go well together. It's par for the course.
Matt
Old Jul 18, 2007 | 07:55 PM
Tomcatta's Avatar
Tomcatta
I sort of figured as much but just wanted to make sure. Thanks!
Old Jul 18, 2007 | 10:32 PM
polizei's Avatar
polizei
If you plan on modding it at all, a pulley will get rid of this problem.
-Cody
Old Jul 18, 2007 | 10:39 PM
SHRTSTAK's Avatar
SHRTSTAK
-Cody
Ehh, not in my '06.
Old Jul 18, 2007 | 10:40 PM
cooper99's Avatar
cooper99
I disagree with you on this one Cody.
If its 90+ degrees out and I'm in traffic with the A/C blasting, my engine feels so weak when starting from a stop. I just have to give it a little bit more gas and bleed the clutch in when I'm taking off. The car definitely revs a lot freer with the A/C off hot traffic, but the a/c will definitely be on when I'm driving it.
As Dr. O stated, it's just one of those payoffs you get with a small SOHC 1.6L engine.
Old Jul 18, 2007 | 10:47 PM
Tomcatta's Avatar
Tomcatta
I really appreciate all of the opinions! Thanks for confirming what appears to be "normal". I guess it's a very small trade off during the hot weather.
Old Jul 18, 2007 | 11:56 PM
retroom's Avatar
retroom
Yeah you have to live with it. The solution......I turn off the AC for a few seconds then turn it back on when up and running...
retroom
Old Jul 19, 2007 | 05:22 AM
resmini's Avatar
resmini
My MC has the problem, I don't know if it's worse than the MCS, but it is downright dangerous at times.
Old Jul 19, 2007 | 05:38 AM
rhawth99's Avatar
rhawth99
That's the reason my wife is driving an MCSa instead of the MCa. With the AC on, the '05 MCa was very sluggish.
Old Jul 19, 2007 | 05:53 AM
muy_mini's Avatar
muy_mini
After installing a 16% pulley, I was impressed in how it helps at the low-end. Especially with the A/C on and during a low RPM launch...
Old Jul 19, 2007 | 06:31 AM
minjae's Avatar
minjae
eh. i got used to my ac. i still sweat a little at times. but that's when you gotta NOT stop and run those stop signs and red lights..hahah kidding of course.
Old Jul 19, 2007 | 06:58 AM
Dr Obnxs's Avatar
Dr Obnxs
Only solution is more gas...
while a pulley helps some, remember, this is off idle acceleration, and the pulley doesn't really kick in until about 3k RPM. An expensive way to fix it is a head that really boosts low end torque. But this is just the nature of the beast with small motors. A/C compressors take a bunch of power, and the car doesn't make that much off idle.
Matt
Old Jul 19, 2007 | 07:06 AM
Loony2N's Avatar
Loony2N
True, there is no getting around the fact that the a/c will sap power and this is most noticable when starting off from a stop. But, if you notice a signiciant degradation, or significant engine shake, a relay may be bad. When the a/c is on, the idle should kick up to be close to equivalent of idle without the a/c on. This obviously won't bring back lost power, but it will make idle smoother and decrease stumble on start off. To test, when idling, if the a/c is on, switch it off. Idle will momentarily jump, then return to normal. Conversely, if the a/c is off, turn it on. There should be a very brief dip in rpm, and then a return to normal.
Old Jul 19, 2007 | 07:07 AM
findude's Avatar
findude
The easiest and cheapest fix for this "feature" is in your own hands, er, feet. You only need to adjust when you engage the clutch relative to when you press the accelerator pedal. You need to give the engine a fraction of a second to rev up from idle before letting the clutch grab. Once you master this, the problem goes away . . . .
Old Jul 19, 2007 | 07:08 AM
Dr Obnxs's Avatar
Dr Obnxs
Idle speeds...
warm car, no A/C ~800 RPM
Warm car, with A/C ~1100 RPM.
Still far from the power band.
Matt
Old Jul 19, 2007 | 07:18 AM
Loony2N's Avatar
Loony2N
Matt
Very true. My point is, you will be less likely to "stumble" at take off.
Old Jul 19, 2007 | 08:04 AM
chava007's Avatar
chava007
Last saturday it was around 42C (107F i think), I had my A/C on full blast for the first time.... I am soo happy to see im not the only one with this problem.... I recently bought my car and I thought I hadn't still gotten used to the clutch... it was HARD taking off.... I opted for lowering the level for every takeoff....
Old Jul 19, 2007 | 08:34 AM
kapps's Avatar
kapps
Matt
1100 rpm idle? Mine is ~800 rpm whether that A/C is on or off .
Old Jul 19, 2007 | 08:58 AM
MINIdave's Avatar
MINIdave
The other factor no one is mentioning is the tall 1st gear...........it's a bit of a PITA around town, kicking the A/C off realy does make a difference, but it's also a PITA and a distraction when you're in traffic. Just slip the clutch a bit more............or I guess one could put on a set of 15's with smaller rolling radius tires, effectively lowering the gear ratio...........
Old Jul 19, 2007 | 09:32 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
I agree, but since I don't use my A/C very often, I always stumble for the first few starts until I remember that.
Old Jul 19, 2007 | 12:10 PM
505Bones's Avatar
505Bones
When we're out at the track, we have A/C off and DSC off because of the sluggish start. It gets hot in the MC!
Old Jul 20, 2007 | 05:15 AM
muy_mini's Avatar
muy_mini
A pulley upgrade doesn't just kick in at 3K. The supercharger is spinning faster at ALL RPMs. A pulley upgrade helped enough for me to not consider lazy take-offs, with the A/C on, a liability... -B
while a pulley helps some, remember, this is off idle acceleration, and the pulley doesn't really kick in until about 3k RPM. ...
Matt
Old Jul 20, 2007 | 08:00 AM
Dr Obnxs's Avatar
Dr Obnxs
Look at the torque curve of a MCS...
and it sucks down low. And all those dyno plots were at wide open throttle, that closes the by-pass valve and generates maximum boost when you floor it. If you don't floor it, the valve may even be partially open. Sure the SC is spinning, but it's not moving much air. Here's a boost curve to show what I mean.....
This is from a my 02 MCS car (15% pulley) and at 2000 rpm it is only developing 50% of full boost. Yes pulleys do move the curve down lower, but there's no getting around the fact that the engine isn't a torque monster down low.
Matt
Old Jul 20, 2007 | 08:10 AM
70spop's Avatar
70spop
Edit: eh... changed my mind.
